what do you think?
Old May 22, 2007 | 01:59 PM
muddingmcdude's Avatar
muddingmcdude
Question what do you think?
well i finally got gauges and stuff installed them anyways i found out i only run about 1-2 psi of boost at 60?? does this sound right but if kept to the floor it runs up to 10 pretty quickly and just stays there till i let off and my egts run about 900 when kept to the floor if im climbin a hill it hits 950-1000 soo should i just leave everything alone or adjust the fuel alittle more?
Old May 22, 2007 | 02:00 PM
muddingmcdude
ooooooooooooo and that hose that runs from the wastegate box thing thats round and there a rubber hose that conects the 2 to the front of the turbo that is really loose is that bad ?? cuz i had to tighten it quite a bit and it still wobels soo should i stuff a peice of rubber in there like a gasket ?? or what??
Old May 22, 2007 | 02:14 PM
muddingmcdude
hah and another quesiton i just thought of i bought a speed senser for my speedo Where is it located is it on the transfer case cuz that looks like the one i got?? i want the one to fix my bouncing speedo after 65
Old May 22, 2007 | 03:20 PM
PLC7.3's Avatar
PLC7.3
Speed sensor should be on the axle pumkin.......
