General Diesel Discussion
Ford E350 Camper/RV
Old May 22, 2007 | 03:07 AM
moremeba's Avatar
moremeba
Ford E350 Camper/RV
Hi All, im a newbie on here and have a question regarding the possible purchase of the above.
Its a 1979 model and has a 7.5 litre V8 ford engine. I live in the UK, gas prices and 7.5 litres of motor are not a good combination.
I was wondering if their is the possibility of chnaging the motor on this for a diesel motor? Has anyone seen or done this type of conversion before? and also know if its possible to source these parts in the UK.
Any help advice greatly appreciated.
Barry
Old May 22, 2007 | 10:50 AM
hotroddsl's Avatar
hotroddsl
I have seen a couple of perkins swaps over the years & I would think you could get a good supply of those units on youre side of the pond & I believe the 6.9 & early 7.3 may fit that generation of van, have you considered a 5.0 petrol motor as they are very efficent & plentiful as well as aftermarket fuel injection is redily available & it was a standard engine in those vans. kindest reguards, Jim.
Old May 24, 2007 | 02:04 AM
powerstroked162's Avatar
powerstroked162
Cummins 5.9l ISB all the way!
Cowboy Steve
Old May 24, 2007 | 02:37 AM
hotroddsl's Avatar
hotroddsl
that's too tall & too long for that engine compartment the 4 cyl Perk. barely fits length & height wise & the ISB is longer by 21" & 7" taller! them vans suck for swaps.
Old May 24, 2007 | 02:48 AM
powerstroked162
Well hells bells, what about a 4bt then?
Cowboy Steve
Old May 24, 2007 | 11:01 AM
hotroddsl's Avatar
hotroddsl
now that just might fit in there! & it sure would make more power than the perky!
Old May 24, 2007 | 12:52 PM
powerstroked162
Yes Sir! It'd sound way cooler to
Cowboy Steve
Old Apr 11, 2008 | 04:19 PM
fordman90's Avatar
fordman90
Thumbs up Cube van
Hi there I have a 1990 E-350 cube van that has a prepowerstoke 7.3L IDI diesel in her. It is a fantastic engine currently have 320 000 on it and is still strong. I would highly recommend that you put one of the 6.9 or 7.3 prepowerstroke in your van. I get over 20mpg with a stock engine. There are some problems, the engine is in a strange place (kinda 1/2 under the hood, and juts into the cab a little) this makes it rather hard to work on. The engine is also vary heavy 1000lbs+ but other than that its great. It is made by international and the block often doesn't need an overhaul till well over 500 000km if taken care of.
Old Apr 14, 2008 | 10:39 AM
884x4broncoII's Avatar
884x4broncoII
i would say its possible, the 7.3 came in the E-platform only in the 1 ton version. probably easiest to swap in an idi 7.3 allot less wirering to f'with, your best bet is to find an complete e350 diesel van as your donor for the swap
Old Apr 16, 2008 | 01:59 AM
mnmwhit's Avatar
mnmwhit
you can order a brand new E-350 with the 6.0 PSD diesel. Ask your camper dealer to order it.
Old Apr 16, 2008 | 04:19 AM
884x4broncoII
he is looking at an 1979 motorhome not a bran new one
3Rs
18
Sep 20, 2014 07:22 AM
fordf350camper
Apr 28, 2013 02:47 PM
Martyn Greenwood
Dec 25, 2005 10:03 PM
78fordman
Modular V8 (4.6L, 5.4L)
Feb 19, 2004 10:33 AM
