Offroad & 4x4
Dana 44 front dif ?
Old May 21, 2007 | 11:50 PM
Broke_Okie's Avatar
Broke_Okie
Dana 44 front dif ?
I have a dana 44 out of a 76' 1/2 ton 4x4, it is a coil front dif. I want to know if the hub and rotor assy off of an 8 lug leaf Dana 44 will bolt up to my 5 lug spindles? I want to put a dana 60 in the rear and want matching 8 lug up front. I would do a dana 60 up front but cannot afford at this time so I fugured I would put 8 lug on my 44.
Old May 22, 2007 | 06:15 AM
SoArkSI's Avatar
SoArkSI
as long as they are both open knuckle axles, then it should be ok, but i believe that you will have to replace the knuckles also in this swap.
Old May 22, 2007 | 07:01 PM
kjett's Avatar
kjett
If your new axle is a ball joint with the 276x u-joints, then the 1/2 ton knuckles will work by just swapping in the 3/4 ton caliper brackets, calipers, spindles, and hubs/rotors. They both share the Ford specific 5 stud spindles. If you can get a set of 3/4 ton knuckles it may be worth it as they are a little beefier than the 1/2's (i.e. thicker material in some spots).
Old May 24, 2007 | 09:51 PM
Broke_Okie's Avatar
Broke_Okie
Thanks guys. I hope to get this goin soon.
samickguy15
Apr 26, 2020 03:12 PM
amosmoses
Dec 19, 2013 07:32 AM
351slug
Offroad & 4x4
48
Jan 29, 2011 07:38 AM
mattjensen
Apr 24, 2009 04:28 PM
ag30265
18
Jul 29, 2008 12:43 AM
