Dana 44 5-lug to 8-lug conversion
Has anybody ever modified a Dana 44 from 5-lug to the 3/4 ton 8-lug pattern??? My buddy has a '93 F-250 4x4 with the TTB front end with leaf springs. He wants to switch to a solid front axle. I can get a hold of a set of axles out of a '79 F-150 for cheap, so we were looking into the possibility of switching spindles or hubs to accomidate his truck. If anybody has any info that would be great.
Thanks,
Aaron Weyhrich
Thanks,
Aaron Weyhrich
everything bolts on from the ball joints out, BUT, the axles wont fit your buddies truck, they are coil spring axles and set up totally different, his best bet is a 1980 or newer (different years are better than others, you might need to check it out) dana 60, it bolts right onto the leaf spring front end in that year
Originally Posted by teds74ford
Actually, you don't need from the ball joints out. You only need from the spindles out. Of course, you can do the knuckles if you want, but then you have the steering arm studs sticking up, but don't need them on there
still in all, a later model d60 would be the better choice
I want to do the exact same set up on my 74 f100 using parts from 77 f250 axles, but dont know how. Need help too.. if it's even possible
'79 fourdoor
11-02-2010 01:01 PM
mattjensen
04-24-2009 04:28 PM
gabraham
06-09-2003 05:17 PM
