sled pulling advice!?!?!?!
May 21, 2007 | 10:11 PM
problem is every one is were im at..... they will just stab and steer. its just a local fun get together for fun.
Quote:
Originally Posted by mudracin74
how bout a brake stand to build boost off the line???
If you've never pulled before I wouldn't suggest it. Things happen a lot faster than you think and it's a lot easier to break by boost launching.
they just expect more outta me cuz i take diesels so serious
May 21, 2007 | 10:13 PM
ive pulled alot w/ big block gassers but not w/ my diesel
May 21, 2007 | 10:18 PM
The diesel classes are always 8k lbs., this is a lot heavier than the gas classes. Add the big torque difference and you can see how it is easier to bust stuff.
May 21, 2007 | 10:20 PM
What is the track like? We have some of the stickiest clay you can find. If it's loose dirt lay it in the floor and let it eat.
May 21, 2007 | 10:21 PM
mech2161, thanks for your advice. i was hoping you would chime in on this one.
May 21, 2007 | 10:22 PM
it will be loose. nothin but sand for miles round here. its pretty ****ty pulling conditions actually
May 21, 2007 | 10:24 PM
You can get my number from my web site if you need anything. I may not answer so leave a message and I'll get back to you.
May 21, 2007 | 10:27 PM
If it's that loose you need to walk it out a ways to get the ground speed up before it breaks the tires loose. Use some type of MTR tire.
thanks, i may be in touch. im just trying to make it fair for everyone, and its not a full blown diesel pull just a tractor pull w/ a 4x4 truck pull after to kill time. but i also dont want to look like a retard linening it up if ya know what i mean..
May 21, 2007 | 10:30 PM
I read somewhere unless you are in like an unlimited class you are limited to 35" tire is this true or not?
I think I've been that retard a time or two.
May 21, 2007 | 10:32 PM
Quote:
Yes! Most bigger events have a tire limit.
Mark250
Competition
Jan 1, 2016 07:14 PM
strokin'_tatsch
Texas Chapter
May 24, 2013 09:38 PM
mismith
Jul 19, 2012 11:13 PM
houseofdiesel
Oct 14, 2009 11:36 AM
mk4poa
All Things Towing
37
Mar 26, 2006 12:56 PM
