Hypereutectic Flat or Forged Disc?
Old May 21, 2007 | 05:13 PM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
What does this mean? I am shopping for a rebuild kit and ran across this. I guess it has to do with the pistons, but what?
Old May 21, 2007 | 06:06 PM
ri_truck_guy's Avatar
ri_truck_guy
Hypereutectic refers to a multiple component alloy...in pistons they're suppossed to be stronger and run with less friction than a forged piston.
Old May 21, 2007 | 09:32 PM
Franklin2's Avatar
Franklin2
Cast pistons are stock, and can run close tolerances in the engine to reduce noise(knocking sounds when cold).
The Hyper's are something special like Bill said, which makes them stronger than cast, but they can be run close tolerance so they are still fairly quiet.
The forged are what the racers use, are the strongest, but swell up a lot when they get warm, so the tolerance in the block has to be kept large. So they are noisy when first started. They are also very expensive. They are made by taking a hunk of aluminum, and pressing the piston out, which compacts the aluminum, making it stronger.
Old May 22, 2007 | 04:28 AM
ScottInTexas
Thanks guys. Now, back to shopping.
Old May 22, 2007 | 09:06 AM
f100beatertruck's Avatar
f100beatertruck
It was my understanding that many of our trucks (at least 302s) came factory with forged pistons. I know Mustangs up to 92 were forged. Also while searching for pistons for my mustang there are some reasonably priced forged pistons available. Speedpro has a set with rings for like $250.
David
