Aerostar Ford Aerostar
Steering wheel position....
Old May 21, 2007 | 02:40 PM
Pablo-UA's Avatar
Pablo-UA
After R'n'P rebuilding, my steering wheel is turnes 70 dgr CV, when I drive straight. Pinion was not installed in correct position tor 3 teeth. Need advice. How to correct situation w/o rack and pinion remooving.
Old May 21, 2007 | 04:49 PM
cookkd's Avatar
cookkd
Pablo,
Why not pull the steering wheel and center it????
Old May 22, 2007 | 12:13 AM
Pablo-UA's Avatar
Pablo-UA
I thought about it, but belive me, it is impossible on '89 aero.... I can turn steereng wheen 180 dgr only. And pinion is designed that I can install shaft in 1 position only.
Old May 22, 2007 | 08:40 AM
Bear River's Avatar
Bear River
Former ******
Well, I think you just answered your own question. You need to either live with it or reset that pinion gear.
Old May 22, 2007 | 08:48 AM
Pablo-UA's Avatar
Pablo-UA
reset pinion gear!!!! no way, till no leaks!
Old May 22, 2007 | 08:50 AM
Bear River's Avatar
Bear River
Former ******
Is there a keyway cut inside the wheel? Maybe the solution is to cut a new keyway.
Old May 23, 2007 | 02:27 AM
Pablo-UA's Avatar
Pablo-UA
May be, I'm not sure. Ore to center it with turning tie rods....
Old May 23, 2007 | 07:30 AM
cookkd's Avatar
cookkd
on my 90 and 91 the steering wheel is just a spline fit. I can take it off and move it in either directions a tooth at a time.........
Old May 23, 2007 | 07:49 AM
Pablo-UA's Avatar
Pablo-UA
Unfortunatly my aero is '89....
nddragon01
2004 - 2008 F150
Mar 31, 2024 08:03 PM
blyon70
Apr 10, 2017 08:34 AM
Kelyn Brown
Jul 19, 2016 11:52 AM
Fishfry101
Apr 4, 2014 05:39 PM
F100Mann
20
Sep 10, 2013 06:41 PM
