1978 - 1996 Big Bronco
78/79 BRONCO
Old Jun 9, 1999 | 03:09 AM
79bronco's Avatar
79bronco
78/79 BRONCO
i know i'm asking alot, but i've been searching what seems an eternity for new or after market parts for 78/79 broncos. any help is appreciated greatly. i'd like to finish this project before i'm too old to drive.
Old Jun 10, 1999 | 10:19 PM
Branson's Avatar
Branson
78/79 BRONCO
Try www.autokrafters.com Also go to the previous message area "1990 Bronco Tailgates" and cruise through there, as there's some other good sites... I also like the 78-79 Broncs, they"re great... no smog hassles & tough as a tank ! Auto Krafters also sends out a good snail mail catalog... good luck...
Old Jun 10, 1999 | 10:38 PM
Branson's Avatar
Branson
78/79 BRONCO
My mistake, the 1990 tailgate message is below yours--- Good luck with you project...
Old Jul 21, 1999 | 10:16 PM
CowDawg's Avatar
CowDawg
78/79 BRONCO
Try this. <a href="http://truckworld.com/KbarS/">http://truckworld.com/KbarS/</a>
Old Jul 27, 1999 | 12:38 PM
Jeff Baker
Guest
Posts: n/a
78/79 BRONCO
I couldn't agree with you more. I have a 1978 Bronco that is in quite good shape and in process of being fully restored. Finding parts is a real trick. I would suggest that you do a search on "obsolete Ford parts". You will find several hits that might help. Also, look at K BAR S. They specilize in Bronco parts.
If, during your search, you find an external tire carrier for a 78, I would live to hear about it.
Old Jul 29, 1999 | 12:01 AM
cat78ford's Avatar
cat78ford
78/79 BRONCO
<center><font size="1" color="#ff0000">LAST EDITED ON Jul-29-99 AT 01:06&nbsp;AM (EST)</font></center>
I just found this place and it's great. I've got a 78 Bronco also and am glad to find others, even if none of you are chicks too. I would love an external tire carrier and window motor, if anybody can mail me! We have lots of 77-79 F150 &F250 4wd parts and 351M engines and sources, but not much Bronco info yet. Does anyone know if other year toppers will fit on a 78? Thanks in advance!Lots of parts sources listed in back of 4-Wheel and Off-Road magazine.
Old Sep 23, 1999 | 11:14 AM
Dave Hiatt
Guest
Posts: n/a
78/79 BRONCO
I just removed the swing away spare tire carrier from my '79 Bronco. I thought it made too much racket. I would love to get ride of it. It is in pretty good shape. I live in central Illinois if you are interested.
Dave
217 398-5292
Old Jan 26, 2000 | 01:18 AM
Disguy74's Avatar
Disguy74
78/79 BRONCO
I have a 79 Bronco and am currently building a 460 to throw in it. The 351M that is powering it at the moment is on it's last leg. I recently got out of the Marine Corps and drove it from California to Oklahoma with a car in tow. The beast just kept on a kicken. But to the questions before me. There are some aftermarket rear tire carriers out there and even specialized for tire size. You can find them in most four wheel drive magazines, but you are going to pay an arm and a leg for them. I'm trying to search every salvage yard this side of the Mississippi until I find one, I have heard that vans from the same era might have the same bolt pattern but I havn't been able to prove that theory yet. I would like to know if anyone out there has any input on where to find building information on 460's. Mine came out of a 70' Lincoln.
Old Jan 26, 2000 | 10:54 PM
beast's Avatar
beast
78/79 BRONCO
i don't know how much help this will be but try
www.alltruckparts.com
>to drive.
Old Mar 3, 2000 | 07:15 PM
curt's Avatar
curt
78/79 BRONCO
To the person who is looking fro 78 - 79 Bronco parts. I am restoring my 79 Bronco and I get my after market parts from two sources (1) www.lmctruck.com and (2) www.dennis-carptenter.com
They both have quite a selection. Good Luck, Curt
Old Mar 6, 2000 | 08:27 AM
Jeff's Avatar
Jeff
78/79 BRONCO
I have had good luck with the following sources:
Jeff's Bronco Graveyard (248) 437-5060
Auto Krafters (800)228-7346
LMC Truck (800) 222-45664
K-Bar S (800)266-1941
I hope that these help! Good Luck.
Old Mar 11, 2000 | 01:04 PM
AlM's Avatar
AlM
78/79 BRONCO
YO!
Tabco has many body panels. No www page though:
Tabco, 30500 Solon Industrial Pkwy., Cleveland, OH 44139
a sales lay there has a 78 and is very knowledgeable about each panel.
here is Popular Mechanics www site where a dude describes how he repaired body work:
http://popularmechanics.com/popmech/auto2/9406AUMRBM.html#SOURCE
Good luck, Al
Old Mar 12, 2000 | 10:11 PM
AlM's Avatar
AlM
78/79 BRONCO
DISGUY!!! Here is what a George did to his bronco, hope it helps, Al M:
I have a 86' Eddie B. Bronco that came with a 351w/C6, and I put a 78' 460/C6. I used L&L motor mounts. You also have to have a rear sump oil pan (like trucks have, my 460 came out of a Mercury, so I had to change the pan), and other that that its more or less a bolt in. All the wires hooked up, and with a little fabrication skill, all the belt driven accesories went back on. I don't know about the condition of the 460 your thinking about putting in, but mine needed total rebuilding (both engine and transmission), but that just let me build it the way I wanted to. Mine has about 9.5:1 compression ratio, a hopped up cam, a RV torque converter, and a shift kit in the valve body. Oh yea one other thing. A car C6 (or any car transmission) won't bolt to the transfer case. If you don't want to sell or reuse your old transmission for another project you can swipe the output shaft from the old transmission into the new one. Bad news is to get the output shaft out or put it in you have to disassymble the transmission compleatly, which is no big deal if your rebuilding it anyway, but otherwise it would be easyer to find a working transmission from a 4x4 Big block. The power is great, and the milage is about the same as the 351. Good luck with the swap. and if you have any questions I'd be happy to help, just throw an Email my way. George
in: https://www.ford-trucks.com/dcforum//bigbronco/5.html#
Old Mar 17, 2000 | 10:32 PM
Craigthebull's Avatar
Craigthebull
78/79 BRONCO
I just put a 460 in my 79 bronco L&L and advance adapters make bolt in motor mounts. You have to get a rear sump pan with a dip stick in it and a new oil pick up tube and a main bearing bolt with the extra threads to hold the pick up tube in place.If you have a C-6 it will bolt up with no changes (you will need the 460 flywheel).For the exsaust it's either headers or you have to find a truck manifold for the passenger side a car wont work i tried i know i used the car manifold on the drivers side.(my motor was out of a 76 Merc)
I also had to get truck alt & p.s. brackets from a 460 truck(you can get these from L&L but they are way spendy).Hope this helps
Old Mar 22, 2000 | 10:45 PM
AlM's Avatar
AlM
78/79 BRONCO
DISGUY!!!!!!!!! and y'all!
Here is a dude selling a tailgate, etc. have fun!1980-1996
1961-1979 No
Ad Number: 5676
Date Posted: 03/20/2000
Contact: Nate Pickett
3541 Possum Path
Burlington, Kentucky 41005
US of A
Telephone:
E-Mail: JEGSRACING(No Email Addresses In Posts!)
Spare tire carrier off a 1979 bronco. Brand new 31" tire included $175w/tire $105w/o Also used grille for 79 $20
