Picked up my new '86 F250 6.9 today!
I just bought myself a 1986 F250 4x4 6.9 w/ 180000 miles on the clock and the Banks Power Pack.
Two problems with it right off. a/c doesn't work, and the speedo doesn't work.
No idea how to fix the air, but I do know that the problem with the speedometer is with the gears in the transfer case.... Anyone know how to replace those, or should I just take it somewhere?
Thanks!
Thanks!
actually it is a rebuilt transfer case. here's what happened.....
prior owner (buddy of mine) blew it out. so he took it to place A (no idea what its called) to get it fixed. they put a rebuilt xfer case in there, but it had that messed up part of it...or something. somehow, that place screwed it up. i don't want to go back there to get it fixed for fear that something else will get messed up even more.
There are 2 gears inner and outer the both will wear out but people don't realize that and only change the outer get both...... gear color is important as it reflects the axle ratio. Ford should have a box of them in stock for you to get them. Could also be the cable is broken or the head at the cluster is disconnected. Check some stuff out and get back....
I'll take a look at all that tomorrow morning and get back...
There's one other problem that I just realized today. The glow plugs are intermittent... Sometimes the light comes on, sometimes it doesn't. Usually they won't come on in the mornings... they come on about 75% of the time when the truck is warm. Any ideas?
I'm having to keep the block heater plugged in just so I can start the truck up!
The 86 engine had a coolant temp sensor mounted in the rear of the drivers side head.
When they went bad, sometimes the glow plugs do not come on when they are supposed to, more often though, the glow plugs turn on when they are not supposed to and burn up.
Either way, it is still a problem.
This is the glow plug relay behind the passenger side battery.
Remove the purple wire from the relay, then attach a 14 AWG wire to the terminal.
Run the wire inside the cab and attach it to one terminal of a momentary switch mounted in a convienent location.
Attach a wire tot he other terminal of the switch and run it to a power source, I preffer a source that is only hot when the key is on.
You have just converted your glow plugs to manual operation.
To operate the glow plugs,
Turn the key to On.
Push the momentary switch for 10 seconds.
Start the engine.
After a while you will find you can use shorter times on the glow plugs when the engine is warm or longer times when the engine is very cold.
Turn the key to On.
Start the engine.
