Lost Power
Old May 21, 2007 | 11:06 AM
two9292's Avatar
two9292
Lost Power
I have a 2000 F-350 CC LB 7.3 auto, hypertec tuner, garret ball baring, turbo, ASI intake.
The problem I am having is I have absolutly no power. I came back from a run from Minn. and everything was fine. When I got home I installed a 100 gallon fuel tank, with a fuel pump and lines that go into my filler neck. I went out on a run this morning and I have absolutly no power. At 65 my pyro is running 800 degrees and boost is running at 5 psi which is normal for me. At full throtle I get 900 degrees and 10 psi which is not anywhere close to normal. So I figured maybe my fuel filter and so I stopped and changed that. No improvement. Do you guys have any other thoughts??? !!!!
Sorry about not using the search feature I am on the road and my wife is typing this out for me.
Old May 21, 2007 | 06:45 PM
Uzumati's Avatar
Uzumati
Check for low fuel pressure?? and any boost leaks at the boots for the intercooler and Ypipe
Old May 22, 2007 | 10:09 AM
ztodd377's Avatar
ztodd377
Forgive my ignorance, but how do you check for boost leaks?
Old May 22, 2007 | 02:44 PM
two9292's Avatar
two9292
Thanks for all that replyed. My truck is now running fine..
Old May 22, 2007 | 02:51 PM
powerstroked162's Avatar
powerstroked162
You have to pressurize the turbo system via air compressor. Most plug off the turbo inlet and force air into the turbo and use a soapy water mixture and spray it on the turbo and intake and check for any leaks. Its a crude method but it gets the job done.
Cowboy Steve
Old May 22, 2007 | 04:39 PM
clintbonnie's Avatar
clintbonnie
Just curious, did you find the problem or did it just fix itself?
Old May 23, 2007 | 09:03 AM
mshostek's Avatar
mshostek
I too would love to know how you fixed it? My truck is behaving very similar.
Old May 23, 2007 | 01:43 PM
powerstroked162
He must be shy.... poor little fella
Cowboy Steve
Old May 24, 2007 | 10:49 PM
two9292's Avatar
two9292
Just got back from my montana run. The problem is the elbow in the X pipe that goes to the map sensor. It came out once before but it was at high boost, this time it must have happened when i started the truck. This elbow is no longer a tight fit. Has anyone else ran into this problem?
Old May 25, 2007 | 08:57 AM
mshostek's Avatar
mshostek
Where is this located on the xpipe? Is it easy to get to? How big is this elbow?
Old May 25, 2007 | 12:02 PM
two9292's Avatar
two9292
the easiest way i can describe to you how to find it is. Look on the passanger side firewall mounted to the hvac duct (in the engine compartment) there is a sensor mounted to a bracket. This sensor has a hose and an electrical connector. Follow the hose to the xpipe. The elbow is about 1/4 " diameter.
Old May 25, 2007 | 12:52 PM
clintbonnie
You mean the metal hose fitting came out of the aluminum housing?
Old May 25, 2007 | 03:50 PM
two9292's Avatar
two9292
yesssssssssss
