Bronco II Ford Bronco II
Help!!!
Old May 21, 2007 | 10:43 AM
pitchblacknight27's Avatar
pitchblacknight27
Help!!!
I have an 88 Ford Bronco II 2 wheel drive ABS 5 speed. My abs light stays on all the time and the brakes are sticking. When I go in first it jerks like they are braking. My emergency brake is always off and the light doesn't come on until I start to go. Is there anything I can do????
Old May 21, 2007 | 04:12 PM
kernel-panic's Avatar
kernel-panic
The cause of the problem is usually one of two things: Either the sensor on the rear differential is bad, or the ABS proportioning valve is sticking. There are procedures for pulling codes from the control module in the Read First / Tech section of this forum. Most of the time, it usually ends up with the valve rebuild or replacement to correct the problem, but could be a sensor replacement is necessary as well. Hope this helps.
