Need help identifying engine
Old May 21, 2007 | 08:38 AM
nsaikia's Avatar
nsaikia
I saw this engine in local junk yard. It is bigger to be a Windsor (I think). Most notable are the engine mounts - completely different than 302 I have. Another think that looked different is the spark plug lay out. If I remember right, the passenger of my 302 all spark plugs slant to towards the front, while all plugs in the drivers side slant towards the cab. But in this engine, on each side, two slants towards the cab and two towards the front. I took some pictures with my phone, but haven't been able to download them yet. I will post some once I can.
Do you guys have any idea what engine this could be? Is there any place with engine references (and perhaps pictures) to identify engines?
Old May 21, 2007 | 10:39 AM
mustang81's Avatar
mustang81
need engine identification numbers.plate on carb,on valve cover,front of the block.... look everywhere.
Old May 21, 2007 | 12:22 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
2 forward facing and 2 rearward facing spark plugs? Sounds like an FE (360/390 family) to me.
Old May 21, 2007 | 12:35 PM
mustang81's Avatar
mustang81
332,352,360,361,390,406,410,427,428 engines in the FE big block.You should also try the FE forum.
Old May 22, 2007 | 02:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Identification (rev):
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
-There are other indicators but these are enough to distinguish engine families.
Old Nov 19, 2008 | 05:37 PM
ray conti's Avatar
ray conti
i have a 1979 ford ambulance converted to a work truck looking for a 460 engine and when they ask internal or external balance i dont know how can i tell what i have
Old Nov 20, 2008 | 10:04 PM
Colo79Ford's Avatar
Colo79Ford
Not too familiar with the 460's, but im building one and starting to read up on them a bit....
I think that up until 79 all 460's were internally balanced. After 79 they were external balanced.
Look for weights on your flexplate, if it has weights, it is an external balance engine. Also look at the spacer that is behind your harmonic balancer , if it is just a round sleeve type spacer, it is an internal balance engine... if it is a round spacer with a weight on it (some say it looks like a hatchet) then it is external balance.
dwrestle
Feb 23, 2014 07:47 AM
wescon
Aug 21, 2010 11:18 AM
SteelHorse08
2004 - 2008 F150
May 6, 2008 07:03 AM
cobrajet427
Colorado Chapter
Apr 13, 2008 05:00 PM
