1978 - 1996 Big Bronco
Starter Location 91 Ford Bronco
Old May 13, 2000 | 04:26 PM
uacat36's Avatar
uacat36
I know this is a stupid question but I just want to make sure. Is the starter located underneath the truck on the passenger side by the 02 sensor and the transmission. I believe it is the black cylinder that is bolted onto the tranny. Is this correct?
Thanks for all your responses
Old May 13, 2000 | 06:29 PM
PAUL_2's Avatar
PAUL_2
Yes , thats the starter . Are you having a problem with it or just curious ?
Paul
Old May 13, 2000 | 09:29 PM
uacat36's Avatar
uacat36
Paul,
Thanks for the information! Here's the situation. Today, when starting the truck, the starter makes a "whine" it never did before. The volt-meter on the dash has not changed so I believe the battery is still OK so I am assuming that the starter is starting to go out on me. What do you think? The car still starts it just takes a bit longer to start up and once started everything is as it should be!
Thanks again for the help!
Patrick
Old May 13, 2000 | 09:53 PM
PAUL_2's Avatar
PAUL_2
Patrick ,
Before you condem the starter verify the battery is ok , Have it load tested . Next check both cables for corrosion . Internal corrosion is not always visible , you have to closely inspect the cables . The Negative battery cable that goes down to the starter also bolts to the frame , the cable is bare where it bolts to the frame ...this is often a place where corrosion starts . Always start with the basics and work your way to more labor intensive problems . This will make sure you solve the problem the first time w/o spending money unnessecarily on parts that aren t defective .
Paul
Old May 15, 2000 | 11:10 PM
Treygirl's Avatar
Treygirl
Soldier26
General Diesel Discussion
Aug 17, 2015 11:30 AM
Auztone
Aug 2, 2009 09:04 PM
boeing777
Jan 29, 2009 07:50 AM
honeyCANdew
Electrical Systems/Wiring
Jun 14, 2004 05:53 PM
shadowcatcher
Sep 29, 2003 05:04 PM
