Sponsored by: Real Truck
lift kit
Old May 20, 2007 | 07:48 PM
twodazeoff's Avatar
twodazeoff
lift kit
I have a 05 f250 sd, crew, 4x4, v10 and I am concidering a 4"lift. My question is does the lift affect towing/ handleing? I tow a 30 ft camper and I really don't want to change how it handles. But like the looks of the lifted trucks.
Old May 20, 2007 | 08:08 PM
spunks00's Avatar
spunks00
is that 5th wheel? if it is you have to concider the hitch and stuff, if not then a drop hitch would be fine, i think only 4in you will be fine towing wise, whats that trailer weigh?
Old May 20, 2007 | 08:47 PM
twodazeoff's Avatar
twodazeoff
It is a tag behind and weighs in at around 6500lbs.
Old May 20, 2007 | 09:03 PM
chewy8000's Avatar
chewy8000
I don't think the Donahoe Racing 4.5 hanger kit effects towing at all. I would go with that one.
Old May 23, 2007 | 12:13 AM
spunks00's Avatar
spunks00
he has an 05, they have coils not leafs in the front you, cant use hanger drops, maybe coil spacer...(i am not up on coil springs)...but i think 4.5 would be too much for a spacer
Old May 23, 2007 | 11:19 AM
Overkill's Avatar
Overkill
FTE *******
Twodazeoff,
The DR 4.5" system will not affect towing capacity and will retain your stock overload springs. We have quite a few customers who tow on a regular basis with this system without issue.
Here is an example of a DR 4.5" system on 35s:
Old May 23, 2007 | 12:22 PM
F250tuff's Avatar
F250tuff
Marty, with the 4.5" DR and 35's on a '06 F-250, is that too tall to pull a 5th wheel or goose neck? I'm considering going with this setup in the next 12 months or so. Although I don't currently pull a 5th wheel or goose neck, I may have the need some day. I don't won't to make my truck worthless for what it is made to do.
Thanks
Old May 23, 2007 | 01:12 PM
texcan's Avatar
texcan
Mine accually tows better with the camper on, now that it's lifted.
Old May 23, 2007 | 01:53 PM
Overkill's Avatar
Overkill
FTE *******
Thanks
This system only lifts the rear 1.375" over that of a stock F350, but the tailgate height changes less due to it's pivoting around the rear axle when the front end is leveled. The bigger difference comes from the actual tires which in the case of 35s will result in roughly a 2" increase in ride height. I have many customers who pull 5th wheels and goosenecks with as much as 6" systems without issue.
Old May 23, 2007 | 08:23 PM
F250tuff's Avatar
F250tuff
Great. Thanks!
Old May 23, 2007 | 09:29 PM
ecky's Avatar
ecky
Question:
Why can't you use the DR 4.5 kit on a truck with manual tranny. I saw that on their website. Thanks.
Old May 24, 2007 | 04:10 PM
Overkill's Avatar
Overkill
FTE *******
Originally Posted by ecky
Question:
This is due to the design of the radius arm drop brackets which overlap the transmission crossmember. The crossmember on manual trucks is further back and the DR brackets do not have sufficient clearance to accommodate for this. Here is an example: (Note the second set of holes just behind the crossmember. These are for manual transmissons.
Old May 24, 2007 | 04:41 PM
lawlessinmt's Avatar
lawlessinmt
When I inquired about the DR kits awhile back(I also have a manual tranny on an 08)I think DCSpecial said they can substitute an adjustable radius arm drop bracket.Is this correct?I will be interested in a 4.5 DR kit down the road aways for my 08.I am also looking to replace rear springs instead of using higher blocks-this wasn't available for the 08's last I checked.My problem is locally noone even knows about DR-and will not install anything they don't sell themselves.
Old May 24, 2007 | 06:26 PM
Overkill's Avatar
Overkill
FTE *******
We have installed Fabtech radius arm brackets with DR systems on manual trucks in the past. This solves the clearance issue . We will have Rize 6" rear springs for '08 SD available next week. Let me know where you are located and I can try to find an installer in your area. Thanks
Old May 24, 2007 | 09:06 PM
ecky's Avatar
ecky
Overkill
Thanks for the info. I'm not ready to lift mine yet, was just doing some pre-planning I guess. Thanks again.
