PC issues...
Old May 20, 2007 | 12:15 PM
tcbofade's Avatar
tcbofade
PC issues...
Argh...
I'm a bit frustrated guys. One certain unnamed teenybopper was on my pc. Found on of those "Get 10 bazillion free smilies...click here" type deals, and proceeded to trash my pc.
I think that I have all of the virus removed, but the registry is trashed. No, I don't have the windows software to just format the darn thing. I've tried various registry repair programs, none of which seem to solve the issue.
So, now I'm on the girlfriends pc, running around the net downloading various fixes, sending them to floppy disk, and running them on my pc. I am making progress, but the thing is not repaired.
I've got no desktop, and seem to be missing registry files.
Windows 2000 NT.
Any ideas?
Old May 20, 2007 | 02:09 PM
Uzumati's Avatar
Uzumati
Hopefully you are not logged in on the local admin account.
Log in as local admin and got to
C:\documents and settings\<username> and delete all files that start with NTUSER. you will have to "Show hidden files". Then log back in as the affected user and the profile will be recreated.
Old May 20, 2007 | 02:43 PM
tcbofade's Avatar
tcbofade
Hmmmm. I really can't log in as anyone. I don't get a start up bar, or start up button. I get a blank screen. I can use task manager to run various commands, but that's about the extent of my abilities at the moment.
I have managed to open several of the anti virus programs and run them, and the issue now seems to be missing registry files, as opposed to corrupt ones.
I wonder if I can download specific files from another pc and copy them over?
Old May 20, 2007 | 02:55 PM
Mil1ion's Avatar
Mil1ion
Can you take a print screen of the ones that are missing ?
Old May 20, 2007 | 03:07 PM
tcbofade's Avatar
tcbofade
Um, apparently not. Anytime I give a command to print something, or save to a disk, it accepts the command, but does not perform the action.
Right now, I'm showing four non existent files, and four empty registry keys.
Old May 20, 2007 | 03:42 PM
rebocardo's Avatar
rebocardo
Look for a file called 8kernel*****, it is a virus. Delete it.
Did you happen to create a repair disk even once with the -rdisk command?
If you have data you want to save, you can make your C: drive your secondary, install a new hard drive, make it your primary, and install a new OS.
Look on your C: drive for a bunch of .CABS, you might be able to reinstall the whole OS or IE.
Can you run CMD to browse your drives or run your virus program?
Old May 20, 2007 | 03:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
run system restore to a date before the teen got to the pc. this should isolate the bug. then run a good antivirus to clean it up.
Old May 20, 2007 | 04:25 PM
tcbofade's Avatar
tcbofade
I don't have a system restore option...that I can find anyway.
Yes, I can access command prompts. No, I don't have a rescue disk.
I don't have another hard drive laying around, and do NOT want to mess up the pc I'm using as it is borrowed. Humph.
I'll go look for .CAB files, but I haven't noticed any yet.
Old May 20, 2007 | 04:37 PM
tewferford's Avatar
tewferford
Go to all programs, then accessories, then system tools, then system restore.
Old May 20, 2007 | 04:56 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Terry, at the command prompt, can you run msconfig
On windows xp, you can access windows restore after typing in msconfig. Not sure if it is an option under windows nt.
Old May 20, 2007 | 07:14 PM
jake00's Avatar
jake00
to the guys who suggusted sys restore, Win2k doesn't have that option, only xp and later
Old May 20, 2007 | 07:22 PM
tcbofade's Avatar
tcbofade
Thanks, but nope. "msconfig is not recognized as an internal or external command, operable program or batch file."
I'm at "c:\Documents and Settings\Terry>_
And can't seem to get much of anywhere. If I reboot the system, I can use task manager to get to some of the windows components, but not all of them. I can get to registry editor, but I'm not able to fix a problem that I can't identify.
Old May 20, 2007 | 07:34 PM
glruff's Avatar
glruff
Can you boot your computer in "Safe Mode?
Old May 20, 2007 | 07:35 PM
tcbofade's Avatar
tcbofade
Yes, but I still don't get a start button or any icons on my desktop...
Old May 20, 2007 | 07:38 PM
glruff's Avatar
glruff
Can you IM on the computer you are using?
If you can, contact me, glruff513
