1978 - 1996 Big Bronco
Brakes
Old 05-01-2000, 04:13 AM
duck's Avatar
duck
duck is offline
Brakes
Heres the problem, however simple it may be to someone else, I'm lost. When I first start my 1993 Bronco (351), after its been sitting for awhile, when I hit the brakes they sqeal. Not only do they sqeal, but the slightest pressure on the brakes, cause the tires to lock up. After running awhile everything works fine....Any suggestions would be appresiated.
Old 05-22-2000, 08:48 PM
elsfarm's Avatar
elsfarm
elsfarm is offline
Brakes
It's a pretty normal problem. Mine does it too. There are little 1/4" size holes or indentations on the brake pads. They fill with brake dust or anything else that can get in them. After they warm up or you use your brakes once or twice it goes away. Next time you get new pads or are in the autoparts store take a look at the pads.
jason
Old 05-26-2000, 01:31 AM
gensis1000's Avatar
gensis1000
gensis1000 is offline
Brakes
maybe calipers are hanging up as you did say the turck had been sitting for a while, right?
Old 05-26-2000, 04:15 AM
duck's Avatar
duck
duck is offline
Brakes
Yea-but when I say awile, I just mean longer than a day. I have a company car, so the Bronco doesnt get driven but once or twice a week. The abrupt braking is really a nuissance. I'll check the brakes (pads etc...) this weekend.
Thanks for the input.
Old 05-30-2000, 07:22 PM
Torky's Avatar
Torky
Torky is offline
Brakes
Old 06-12-2000, 01:56 PM
n5mj's Avatar
n5mj
n5mj is offline
Brakes
There's a TSB (93-4-6) that might apply to your brake problem - my '93 does the same...
The gist of the TSB is that hot and humid environments cause the rear brake linings to grab when cold.
The fix is the replace the rear brake shoes with a set that isn't as sensitive (absorbent?) to humidity.
Good luck.
Mike
Old 06-13-2000, 11:13 AM
bigmhoff's Avatar
bigmhoff
bigmhoff is offline
Brakes
My 1995 does the same thing. It goes away after the first one lousy stop.
1995 Bronco Eddie Bauer- 351ci- 4" Pro-Comp lift- 32" Dunlops- Front & rear Maniks- K&N FIPK- Dynomax 3" catback- Awia Head and changer.
akblackfoot
07-19-2016 12:13 PM
Demo-man
6.7L Power Stroke Diesel
08-18-2015 08:28 PM
SHIP4BRAINS
2009 - 2014 F150
21
07-30-2014 07:14 PM
wtourvil
2004 - 2008 F150
07-03-2008 03:03 PM
argonaut
11-29-2001 12:12 PM
Quick Reply: Brakes
