1978 - 1996 Big Bronco
84 Rear Window Rattling Problem
Old Jun 15, 2000 | 02:37 PM
sbxlt's Avatar
sbxlt
I got a 84 xlt...the rear window seems to rattle alot with the window fully down. I've tried wedgeing paper,rubber,plastic,etc.. that didn't work.
I haven't actually looked in the tailgate at the mechanism...how is the glass mounted to mechanism?
I'm planning on taking the top of soon...i want to fix the rattling so it doen't drive me crazy driving around!!!!
thanks all
Old Jun 16, 2000 | 07:10 PM
Bob_VT's Avatar
Bob_VT
I doubt it is the window making the noise. The glass is held in with rivets to a channel and when you window is in the up position over 75% of it rides in a gasket. I would suspect you have other things loose. Press against the tailgate when it is closed and the window is up. Your latch pins may need to be adjusted. Open the tailgate panel and check the tightness of the handle, the window gears and the window channels. (While you are in there a light coating of oil inside the tailgate will help prevent/or slow down the rust... they all rust.)
Old Jun 18, 2000 | 03:53 AM
AlM's Avatar
AlM
dancraig
Jan 11, 2015 04:58 AM
Morg89
Feb 28, 2012 07:42 PM
iwanaflattie
Apr 18, 2011 11:01 AM
trojantiger
2004 - 2008 F150
Apr 24, 2010 04:38 PM
