Hpop leak
Old May 19, 2007 | 12:45 PM
rebelchevy02's Avatar
rebelchevy02
Hpop leak
I believe the back cover (round one held by a circlip) is leaking, i havent taken the hpop apart yet,and its still in the truck and im in the process of cleaning it up, to be sure thats were its coming from, but what kinda seal is there? and were can you get one? think its something NAPA carries?
Old May 19, 2007 | 01:18 PM
rebelchevy02
After cleaning and having someone start the truck while i was under the hood, i found what looks to be a drain plug to be loose...... tightened it back up, no more leaky!
Old May 19, 2007 | 01:48 PM
brokedad's Avatar
brokedad
You Got Lucky But Get Ready For The O Ring To Go On That Puppy Mine Did What Fun It Is.was It The Large One Or The Small One By The Ipr Drivers Side Under The 2 Large Lines
Old May 19, 2007 | 06:00 PM
rebelchevy02
I think it was an 18mm socket, if your sitting on the core support, looking to the back of the truck, its on the right side of the rear cover, and under a sensor that goes straight into the hpop.
schlepprock250
Dec 21, 2014 01:56 PM
6.0techwannabe
Dec 15, 2014 11:16 PM
70T351W
Nov 2, 2014 10:16 PM
Jesser02EX
Mar 20, 2014 11:20 PM
SSSimon
Australia Chapter
44
Aug 1, 2013 07:05 AM
