Programer/Chip
Old May 18, 2007 | 10:59 PM
mtford's Avatar
mtford
Programer/Chip
Whats the best chip/programmer for a 2000-2002 7.3 PSD? Not pushing this truck hard (maybe pulling 3000 lbs. boat if I ever get the time). Don't want to go so extreem that I need to watch EGRs if I don't want to. Looking for better mpg and of course a few more ponies. Oh yeah, its a auto if that makes a differance.
Old May 18, 2007 | 11:04 PM
littledre1's Avatar
littledre1
From what I've read/learned around here the DP tuner is the only way to go. That's the direction I'll be going in once the guages, intake and exhaust are in.
Old May 19, 2007 | 04:43 AM
aklim's Avatar
aklim
Well, you need gauges first. That way you have a baseline for diagnosis should you have mechanical problems in the future.
Old May 19, 2007 | 04:58 AM
zx250's Avatar
zx250
Of the next Riffraff East
Like aklim said, get you some good gauges first. This will allow you to monitor your progess. Sometimes, just tighting a few loose clamps will give you some extra ponies. Oh yeah, my next investment will be a DP tuner.
Old May 19, 2007 | 05:01 AM
aklim's Avatar
aklim
Boost gauge help me diagnose what I thought was EBPV engaging when it wasn't. I could not go over 15 psi and I heard a hissing sound similar to the EBPV going off in the winter. Since it was cold then, I thought it was the EBPV going but when the boost would not go past 15 psi, well, we knew something was wrong since I have made 24 momentarily before the engine defueled.
Old May 19, 2007 | 05:07 AM
zx250's Avatar
zx250
Since you and I are the only ones up now, what was the problem?
Old May 19, 2007 | 07:34 AM
aklim's Avatar
aklim
The crossover hoses were loose. The ones with the orange boots that feed the heads.
Old May 19, 2007 | 08:41 AM
Izzy351's Avatar
Izzy351
Those are commonly called the "CAC Tubes". I fairly regularly put a screwdriver on them to make sure they're tight. When I first got my truck, I had the standard oil on the top & back of the engine -- CCV mod and tightening all the CAC tube clamps cleaned it up...
Joe
