1978 - 1996 Big Bronco
Ford 9"
Old Jul 17, 2000 | 12:06 PM
treefort's Avatar
treefort
Ford 9"
Will a ford 9" 3rd member from an early model bronco(Small style 66-77) fit my 9" assembly in my 84 F-150, are they the same splines?
also it has 3.50(he sais) but didn't all fords come with 3.55's??
can someone please give me the years with the different spline counts??
28 or 31??
Thanks,
Joel Thomas
Old Jul 23, 2000 | 01:54 AM
4x4guy's Avatar
4x4guy
Ford 9"
I can't help with anything but the gear ratios you're talking about. Ford did make 3.50 gears in the early trucks - such as the E.B. 3rd member you're wanting to swap in. My 78 Bronco has 3.50 gears in it now.
It was also my understanding that Ford stopped making the 9" in 83, not 84, as you state your truck as being. Could be wrong tho, wouldn't be the first time.
Old Aug 2, 2000 | 09:17 PM
nitro94's Avatar
nitro94
Ford 9"
Old Aug 3, 2000 | 04:46 PM
indianacowboy's Avatar
indianacowboy
Ford 9"
> the same splines? also it has 3.50
> with 3.55's??
Although all 9" rear as the same "design", there are several things to consider when trying to interchange parts or assemblies.
1) Are the yokes the same? If not, aftermarket u-joints are available to do a coversion.
2) Splines. Your '84 is most likely (never say always with a Ford) 31 spline. I would not be suprised to find that the early Bronco is 28 spline. If you can find a tag on each of the rear ends, the numbers can be decoded (Hollander Interchange is one source) to tell which axles, and ratios you have.
3) 3.50 is a 9" Ford gear, 3.55 is a 8" gear or a 8.8" gear. 3.56 is also a 9" gear, but not nearly as common as the 3.50. Seems most every 1/2 ton Ford 4X4 I have seen has been 3.50 or 4.11. But with Ford, I am sure there are others out there. 3.00 is one that comes to mind.
4) I have seen 9" axle in Ford trucks as late a 86. I did see one in an 87 van. Factory?? Not sure.
Hope this helps,
Mark
Joel Steven
1947 and Older Ford Trucks
Jan 13, 2009 07:28 PM
treefort
Aug 20, 2001 06:02 PM
treefort
Aug 15, 2001 01:11 PM
treefort
Ford vs The Competition
23
Jul 20, 2001 01:36 PM
treefort
Engine Swaps
Jul 1, 2001 05:21 PM
