Sponsored by: Real Truck
cat delete pipe
Old May 17, 2007 | 10:46 PM
richsoucie's Avatar
richsoucie
cat delete pipe
is there anyone that makes a bolt in cat delete pipe for the 5.4l triton v8
Old May 17, 2007 | 10:53 PM
ReAX's Avatar
ReAX
That is illegal and the EPA/CARB is cracking down. However, there is a motorsport clause that if you only operate the vehicle off-road you can remove the emissions components. I don't know of anyone currently producing them, if you do find one, get it quickly.
Old May 17, 2007 | 11:00 PM
richsoucie's Avatar
richsoucie
i dont need toass emmissions thats why i ask
just figured it would be cheaper than a high flow
Old May 17, 2007 | 11:57 PM
ReAX's Avatar
ReAX
1996+ ODB2 catalytic converters are fairly high flow, a big step from the ones available in the 80's. The cost of a shop putting a cat delete pipe on a street vehicle is about $10k, and then shops get leary about working on the vehicle if they notice the cat is missing. Your best option if you must do it is to put a pipe in it's place in your driveway.
Old May 18, 2007 | 11:43 AM
jim0517's Avatar
jim0517
Funny thing is, if you take a 99 SD with the 5.4 to some of the chain muffler shops, their install guides don't show the secondary cat.
Old May 18, 2007 | 12:59 PM
kenneBF250V10's Avatar
kenneBF250V10
Not sure about how the 5.4 will act but as an experiment I removed the cat from my 6.8 and it didn't like it. I lost low-end and not to mention the noise in the cab increased quite a bit. I ended up installing a Magnaflow high-flow cat instead. I've wasted a lot of money experimenting on exhaust systems and have learned the hard and expensive way that these motors require some degree of back-pressure. If you open up the exhaust too much, your low-end power will suffer. I should clarify that I'm speaking from a forced induction perspective, not sure if the same would apply to naturally aspirated applications.
the cleaner
Modular V10 (6.8l)
Nov 15, 2015 09:54 AM
Pridnjoy
Apr 13, 2014 12:09 PM
lakewood
Mar 22, 2013 05:18 PM
dosmthn
Jun 26, 2010 03:23 AM
villestrip
Oct 19, 2009 07:41 AM
