88 F150 5.0lt Engine Question
Old May 17, 2007 | 10:08 PM
Aspiration's Avatar
Aspiration
I've got a 1988 F150 powered by a 302EFI. The Block is a E7 HO Casting. My question to you is, What kind of Factory Pistons were used in this model F150, cast, forged.... are they flat tops, domed or dished, if dished or domed + or - how many cc's? also anyone one know the stock cam specs?
Thanks for any help
Old May 18, 2007 | 07:49 AM
Conanski's Avatar
Conanski
You should have the E7TE casting. The HO motor was not offered from the factory in the trucks. The truck motor uses cast and slightly dished pistons for a nominal 8.5:1 compression ratio. The stock truck cam is really sad, 0.380" total lift at the valve, no more than 250deg duration.
