more power (cheep)
Old May 17, 2007 | 02:55 AM
RedneckExpress's Avatar
RedneckExpress
more power (cheep)
Hey guys, Well I have had my f250 for about 6 months now and here is the deal it's a 96 f250 off road 4x4 with a 5.8 auto. it has 158,000 on it. It runs super well. The owner before me I beleave never took it off the pavment it looks brand new under the hood and under the body very clean. I took it out with my cousen and his 99 f150 to play in the mud and it seemed to be,, well lets jest say my expectations were higher the the truck would do and I was woundering what I could do to put alittle more power to it with out going into the poor house eather in parts or the gas pump?
Old May 17, 2007 | 09:14 AM
Conanski's Avatar
Conanski
Cheap is relative. Sounds like the truck probably has the factory exhaust system on it. If so, drop the whole thing and install longtube headers and a complete 3" single mendrel bent exhaust system. It'll make more power everywhere and you should actually see an improvement in fuel milage.
Old May 17, 2007 | 09:21 AM
quicklook2's Avatar
quicklook2
what were you expectations from this truck?
where did it disappoint you?
it is a very heavy truck to be offroading with as compared to most offroad vehicles.
Old May 17, 2007 | 11:31 AM
pfogle's Avatar
pfogle
Make sure you put high flows cats on it as well as an H pipe to balance the cylinder pressures. This is a good starting point, but it's not going to gain much more than sound.
Old May 17, 2007 | 12:27 PM
Conanski's Avatar
Conanski
No H pipe needed on a single exhaust, and it gains lots more than sound over the factory system.
Old May 17, 2007 | 01:16 PM
RedneckExpress
Thanks guy's
Old May 17, 2007 | 08:31 PM
pfogle's Avatar
pfogle
It MIGHT gain 1hp and maybe 2mpg. I can get a 2mpg increase by just replacing the muffler on a 351w/e4od with a piece of pipe. No other mods. Went from 15 highway to 17.
Old May 17, 2007 | 09:05 PM
eco's Avatar
eco
When it come to auto parts, you get what you pay for unless you have some kind of inside connection and thus end up paying wholesale or dealer cost etc.
If you think you can come up with *cheap* parts in the retail market that are going to do what they are supposed to do, do so reliably and generate a noticable power increase you are dreaming.
And about the headers, it's my experiance that they don't really begin to work until 4000 RPM. Not all that practical for a truck.
Old May 17, 2007 | 09:11 PM
Moore558's Avatar
Moore558
Would underdrive pulleys make a difference at all? I ask cause you can get a set for usually around $100-150.
Old May 17, 2007 | 09:22 PM
eco's Avatar
eco
If you ask me, underdrive pullies are like snake oil. If we are talking about a race motor that spends all it's time above ~8000 rpm, underdriving them would be a good idea to keep things like the water pump etc. from spinning TOO FAST (they were invented for these applications BTW). But on a motor that spends most of its time around ~2500 they are virtually useless AND potentially a bad thing because the belt driven accessories would not get spun fast enough to do their job well.
Old May 17, 2007 | 09:29 PM
Conanski's Avatar
Conanski
You're saying a complete exhaust system with lontube headers is only good for a couple HP? If so you have never done it, or done it correctly.
Old May 18, 2007 | 02:46 AM
RedneckExpress
I know about things like headers and exaust and I know that if I wanted to get nasty quick would be putting on a supercharger I jest dont want to let the redneck in me get carried away with this truck as I did in my last project. I put almost $6000.00 into an 85' bronco 2 that I got for $250.00. Ya in the end it was a little beast but not really worth the trouble.
Old May 18, 2007 | 08:42 AM
Blurry94's Avatar
Blurry94
The base timing can be advanced a few degrees and that mod is free.
I agree in doing a headers and exhaust, but mandrel bent systems are a little more $$$. I'd tend to think a mandrel bent system would be overkill on a stock motor, no power adder and 3" pipe.
