Sponsored by: Real Truck
Had 2 weird electrical issues happen
Old May 17, 2007 | 08:52 PM
Biggziff's Avatar
Biggziff
05 F250 CC SRW V10. Yesterday, I had the truck parked in a driveway for several hours. A few of the windows down. Jumped in and turned the key on to roll the windows up and they would not work from the driver's door. Open/closed the door, cycled the key, played with the switches including the lock-out started the truck, etc. Nothing. My buddy opened the pass rear door and hit the switch and that window rolled up and then everything worked fine. Hasn't done it since.... Seems too random to be something others may have seen, but I thought I'd ask.
Second thing happened today. Stopped to fuel up. Had about 230 miles on the trip odometer. Jumped in the truck and fired it up. All the gauge needles (speedo, tach, temps, etc) went as far counter-clockwise as they can and they just kind of vibrated like they were calibrating. This lasted about 5 seconds and then they all went to normal. I then noticed that all the trip data had been cleared. My trip odometer, avg mpg, mile to empty, etc were all cleared. I have seen the gauges do this on my 04 150 when I was playing with one of my tuners.
Anyone seen anything like either of these things??
Thanks
Old May 17, 2007 | 09:12 PM
wiingnut's Avatar
wiingnut
There is a tsb to check all your fuses under the hood. The fuses may have not been installed properly. I pulled mine and reinstalled when I saw the tsb
Old May 17, 2007 | 09:17 PM
Biggziff's Avatar
Biggziff
Thanks, wiingnut. I'll do that tomorrow. Do you know what year trucks this affects?
Old May 17, 2007 | 10:03 PM
wiingnut's Avatar
wiingnut
I know 05 was one year. That's what I have
Old May 17, 2007 | 10:10 PM
wiingnut's Avatar
wiingnut
Various Electronic and Driveability Symptoms and Codes:
2005 F-Super Duty trucks built before 5-11-05 may exhibit various electronic-related symptoms due to loose/miss-installed fuses in the engine compartment fuse box. These symptoms may be intermittent. The fuses should be inspected to verify they are installed into the terminals in the fuse box and not along side the terminals.
Fuses--Symptoms
#9, 20 amp: Trailer turn signals inoperative
#10, 10 amp: Check Engine Light; Codes P1633, P0446
#11, 10 amp: Speedo bounce, ABS light, Cruise control inop; Codes U1900, U2023, P0500-P0503
#12, 2 amp: Cruise control inop, TBC Fault displayed, chime; Code C2803
#13, 15 amp: Day time running lamps inop
#15, 15 amp: Crank/no start, bucking, stall; Codes P2614, P2617, P1378
#17, 10 amp: A/C inop or not cooling
#18, 10 amp: Crank/no start, bucking, stall; P2614, P2617, P1378, P0611
#20, 10 amp: Trailer back up lamp inop
TSB 05-11-14
i LOOKED THE tsb up and I found it doesn't really apply to you specific, but stranger things have happened it can't hurt to look. Also check your ground wire! Good luck
Old May 17, 2007 | 10:11 PM
blackhat620's Avatar
blackhat620
Here is one of the TSB's
http://www.ford-trucks.com/tsb/fullt...p?tsb=05-11-14
TSB's listed at top of page, click on link.
Hope this helps.
Old May 18, 2007 | 08:14 AM
Biggziff's Avatar
Biggziff
Thanks, guys....this gives me something to look at.
Old May 18, 2007 | 11:37 AM
FortyFords's Avatar
FortyFords
Biggziff ,did you get a ton of rain in the last 24hrs?
or did you drive through alot rain?
If so ,start chking around the fuse panels under the dash and under the hood for evidence of water intrusion into the areas.
Look at the terminals for corrosion and get some dilectric grease and start putting a little on the contacts.
Also chk the main harness plug that goes through the firewall for being loose or corrosion also.
These are a common area for this wierd gremlins.
Disconnect battery before messing with the main harness plug though.
Rich
Old May 18, 2007 | 12:12 PM
Biggziff's Avatar
Biggziff
It rained while I was in Virginia, but the truck was sitting in a driveway under heavy tree canopy. I plan to do just as you said....check everything very carefully and use some dielectric grease on all the connectors, etc.
Thanks much!
Krazyhorse93
Oct 14, 2016 02:00 PM
75_92_95
1978 - 1996 Big Bronco
Aug 19, 2016 10:18 PM
MatzWestman
1997 - 2003 F150
23
Jun 13, 2016 09:14 PM
benny33
Apr 30, 2014 07:05 PM
willystyle21
17
Jan 25, 2004 12:50 AM
