help please!!
Old May 17, 2007 | 03:14 PM
fishinfool96's Avatar
fishinfool96
help please!!
today i tried to change my exhaust manifold. it was cracked also the bolt in the back was broken off in the head, probably why it cracked. Im in desperate need of ideas on how to get it out. Theirs not much room but I think i can get to it from the wheel well. Any ideas please.
Old May 17, 2007 | 04:42 PM
ACarbone624's Avatar
ACarbone624
A torch and some penetrating lubricant. Get it real hot and spray it. Can you get a vice grip on it?
Old May 17, 2007 | 04:52 PM
fishinfool96
No it is just under the surface. I found this thing called the candle trick. U heard of it and does it work.
Old May 17, 2007 | 05:09 PM
ACarbone624
Your gonna have to drill that out....I'd start by using a center punch...then drill starting with a small bit and stepping it up a few sizes....using multiple bits..... until you are real close to the threads...then try to pick out the rest with needle nose pliers....not sure if u have enough room for this though....
Old May 17, 2007 | 05:29 PM
fishinfool96
Thanks for info. Dont really want to drill cause their really isnt much room. Think Ill try the candle trick i found today. Dont really think it will work though. Im really bummed right now. I just bought the truck 2 weeks ago and am now wishing that I hadnt.
Old May 17, 2007 | 06:08 PM
88 f150's Avatar
88 f150
Are you referring to using wax as a lubricant after welding a washer and nut to the broken stud? It can be a tricky weld when it is below the surface and you really cant get to it. Not that it cant be done. You may have to remove the head. Once removed you can drill away or take it to a shop. Sorry guy
Old May 17, 2007 | 06:47 PM
fishinfool96
I believe that I can get to it with a drill if I remove the plastic weel well and maybe the shock. Tomorrow Im gonna try the candle wax but gonna use drill and easy-out not weld. Gonna pray that it works. If not I guess its "off with the head", lol. Its been awhile since Ive worked on a truck, so Im gonna pray.
Old May 17, 2007 | 07:36 PM
ACarbone624
Easy-outs break...so be careful....drilling is safer
Old May 17, 2007 | 08:10 PM
88 f150's Avatar
88 f150
If you are able to get a straight shot at it I suggest. 1. a good penetrant (kroil is my favorite) The longer you can wait the better 2 days is good. 2. Get a center punch and get it perfectly centered. 3. Quality drill bits are a must! If you have reverse bits use them. Start small and increase til you are at maximum without drilling out the threads. Many times the bolt will spin out with the reverse bits. If attempting an easy out use the square type and only drill to the correct diameter. I cannot stress the penetrant and quality bits enough. Your problem will be magnafied X10 if you break a bit or worse an easy out. Good Luck Also squirt the penetrant a few times each day.
Old May 20, 2007 | 06:41 PM
fishinfool96
Well, to all the helpful hints THANK YOU. I just finished working on it (been real busy), got the broken stud out with no damage (thank God). Its all put back together and it sounds much better. I got it out by using left hand drills. I started with a 1/8" then went up to a 3/16" and finally 1/4". While drilling with the 1/4" bit the peice came loose. It came out really east from there. Im feeling pretty good right now. Thank you all.
Old May 20, 2007 | 06:45 PM
quicklook2's Avatar
quicklook2
glad you got it out.
good job!
Old May 20, 2007 | 06:46 PM
ACarbone624
Congrats! I'm glad you got it fixed.
Old May 20, 2007 | 07:20 PM
fishinfool96
Thank you. Theirs one broke on drivers side too, but its not leaking, yet. Maybe next weekend.
Old May 20, 2007 | 11:07 PM
88 f150's Avatar
88 f150
Got to love that feeling. Must be primal? Good work
