6.9 Headbolts/studs
Old May 17, 2007 | 01:43 PM
macman85602's Avatar
macman85602
Lightbulb 6.9 Headbolts/studs
Just wondering...
I have read that on a 6.9 the headbolts are a major weak point on the the motor. Can the holes for the headbolts be drilled and tapped to the 1/2 inch size for the 7.3 or would just using head studs be better or could both be used? I beleve all in all the 6.9 and the 7.3 are the same motor just the 7.3 has a larger cylinder bore so there should be room enough on te pads for the larger bolts/studs.
Just a thought
Scott
Old May 17, 2007 | 03:58 PM
David85's Avatar
David85
Might be possible, but going to thread in head studs would give better results than using OEM 7.3L bolts.
I'm not sure, but I think the stud sizes are close enough that the 1/2" bolt would require a tapping hole that is already smaller than the 7/16" that the 6.9 has.
Old May 18, 2007 | 10:12 PM
Dave Sponaugle's Avatar
Dave Sponaugle
7/16" x 14 threads per inch
1/2" x 13 threads per inch
Changing the threads per inch would make the block threads very weak.
Head studs are made out of hardened metal, the 7/16" head studs have a higher yield strength than 1/2" head bolts do.
Old May 19, 2007 | 12:15 AM
macman85602
I wasn't totally sure how it would work just a thought though
Old May 19, 2007 | 12:16 AM
macman85602
I wasn't totally sure how it would work just a thought though.
Odie the Truck
13
Nov 22, 2014 10:26 PM
Rollin.IH.Coal
Mar 8, 2012 06:36 PM
jhaines
Engine Swaps
Sep 23, 2011 09:12 AM
topgunn
22
Oct 29, 2009 05:55 PM
Jonboy
Jan 19, 2007 04:22 PM
