Sponsored by: Auxito
Brake Lines
Old May 17, 2007 | 12:08 PM
Thomas Hutchins's Avatar
Thomas Hutchins
Brake Lines
Just lost the metal line on my 97 F150 (103500 or so), from Master Cylinder to left rear wheel well and I assume the other llines are in poor condition also.
Question, are sets of pre-bend lines available for a '97 f150 or do I use roll lot tubing and double flare the ends?
Old May 17, 2007 | 03:22 PM
notyettoday's Avatar
notyettoday
your best bet for pre-bent would be the dealer, if you cant find em than go with the double flare method... if it was my truck, i'd just make my own from the get go, pre bent is more than likely an arm and a leg
Old May 17, 2007 | 09:20 PM
fordboy_52's Avatar
fordboy_52
i moved this to the correct foru, better luck here
Matt
