heater control valve
Old May 17, 2007 | 11:40 AM
expy_luv_r's Avatar
expy_luv_r
having trouble with my a/c. I think its the heater control valve or something.but dont know where its located. it will blow heat out the dashboard vents. if I release the vacuum by disconnecting a line under the hood and replacing it, I will get some a/c. but nothing great. the rear a/c works great. was wondering if the hot water is not being cut off to the heater core. or something else. if anyone can shed some extra light on the subject would really be appreciated seeing its almost summer here in Florida !
Old May 17, 2007 | 01:44 PM
sysman_rick's Avatar
sysman_rick
Post
What year expy ??????????? Pop the hood & follow the heater hoses back towards the engine. You should find it.
Old May 18, 2007 | 10:11 PM
expy_luv_r's Avatar
expy_luv_r
its a '99. will follow the lines. I also heard from someone that it could be the blend door which I guess are trouble with the expeditions and the 150's. I also noticed that it changes over to heat if I accelerate hard. and the temp control on the the dash makes no change either way.making me believe its more a vacuum problem than a broken door....I hope.
1996_5.8
18
Mar 9, 2017 05:04 AM
speedyweasel
Jan 17, 2017 08:14 AM
texas2fst
16
Oct 31, 2016 03:34 PM
R&T Babich
Modular V8 (4.6L, 5.4L)
Mar 1, 2016 10:13 AM
hotfalcoon
Dec 4, 2015 05:13 PM
