Admin needs help!
Old May 17, 2007 | 09:43 AM
wiingnut's Avatar
wiingnut
I would check for a weak ground. Corrosion etc.
Old May 17, 2007 | 11:32 AM
BowTieHatr's Avatar
BowTieHatr
make sure you check all your fuses in the fuse box. did you leave it switched on or you just did not use the truck for a while?
Old May 17, 2007 | 12:21 PM
blackhat620's Avatar
blackhat620
Tim,
I vote with the rest that you have a shorted battery. The old battery is pulling all the load from the new battery.
With the dual battery setup, you must change both batteries at the same time, with identical size and rated batteries,
When you hit the key all the power in the new battery is going directly to the shorted old battery.
Replace the old battery now and hopefully you have not damaged the new battery.
Yes your alarm draws power when the truck is off, but a stock truck also draws a small amount of current to keep the computer memory alive. When a vehicle sits, the batteries will discharge over time.
Get a "battery minder" trickle charger and keep your truck plugged into it at all times, and it will keep the batteries fully charged and good condition.
Good luck
Old May 17, 2007 | 12:26 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Disconnect that batt that is showing red! It should start with one GOOD battery. Be sure to cover the battery cables so they don't short to ground or each other. You may have ruined your alternator by putting in one new battery. After you get starting problem fixed, have them test your alternator.
Old May 17, 2007 | 12:36 PM
Brians97F250Crew's Avatar
Brians97F250Crew
I agree ... you've got a bad battery. The "eye" on those type of batteries should be green when it's good. When you said "the charger shows it good till you try and crank it then it shows dead". That right there tells me your battery is toast.
Always replace these is pairs. The weaker batt will always kill the stronger one. Do what BPofMD said and see if it'll start.
Good Luck
Old May 17, 2007 | 12:38 PM
hotroddsl's Avatar
hotroddsl
get youre self a couple of new batteries and youre troubles will go away I have had this problem every other year since moving to Phx the heat (& or cold) just kills them I have gotten the best life out of Optima's but I have yet to make it through the 72 month replacement warranty (more like 26 months is my current record) Kindest Reguards, Jim.
Old May 17, 2007 | 01:23 PM
Brians97F250Crew
hotroddsl ... I know what ya mean. When I ran the Local NAPA you could mark the start of summer and the first cold snap of winter easily. We'd have a run on batteries over a couple days every year like clockwork.
Old May 17, 2007 | 01:27 PM
blackhat620
Yep, change my batteries every 18-24 months like clock work in Phx, heat just kills them. I tried Optima's and they didn't seem to last any longer and are mucho expensive. Went back to batteries from Costco or Sams. Free replacement in the first 36-months no questions asked.
Old May 17, 2007 | 02:54 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Two brand new bats and no workie........all fuzes are OK....when the lights are on and you try to start lights don't even dim....
Old May 17, 2007 | 03:04 PM
blackhat620
Hmmm,
Starter interupt circuit on your A/M alarm not disarming. Is there an override for this you can try.
Old May 17, 2007 | 03:09 PM
hotroddsl's Avatar
hotroddsl
do you have a tilt wheel? could be the rack bail broken I have experienced this on a couple trucks!
Old May 17, 2007 | 03:46 PM
Brians97F250Crew
Admin .. yea sounds like your alarm is causing the issue. I bet if you were able to turn on the ignition and kick starter on ( jump the solnoid ) the truck it'd probably run.
Old May 17, 2007 | 03:48 PM
  #28
IB Tim's Avatar
IB Tim
Brian & Greg...you are real close...
Found it...relay in remote start ...part...of the security system.....
BTW…thank you all, because the bats where toast also, kind of like Keith said …If I would drive the damn thing…ha-ha
Again thank you all
Old May 17, 2007 | 04:08 PM
  #29
blackhat620
Tim,
Glad you found it, tough to troubleshoot electrical over the computer.
Get yourself a battery minder for your batteries.
www.vdcelectronics.com/automotive.htm
www.batterylifesaver.com/battery-minder.html
www.batteryweb.com/batteryminder.cfm
Old May 17, 2007 | 05:45 PM
  #30
IB Tim's Avatar
IB Tim
I am going to order the BatteryMINDer ...seems like the best of all....wish they would show a picture of the life saver one.
