rebuilding options?
Old May 16, 2007 | 10:24 PM
rx7delsol's Avatar
rx7delsol
rebuilding options?
Hey guys i was wondering what would be a good engine for my 95 Flair Side. Of course it has the 302, but the blocks I hear are pretty weak, so I was thinking maybe a 351w. The 351w is pretty much a bolt on swap right? Also, I have to have a turbo, low boost at maybe 8psi. My friend has a 99 Mountaineer with the gt40p heads thats about to get repoed so he told me to swap the heads and intake with mine. so i'm gettng a VERY nice freebie. Here's my question, to make a low boost engine with two t3/t4 hybrids with gt40p heads and intake, would it be better to rebuild the 302 or find a 351w. I will be using stock internals by the way. Also, i think i have the e-aod tranny, will it hold the extra power with a valve body kit or do i have to upgrade the clutches. Or will it be better to swap a 5 speed in and if so what 5 speed to use. i love a manual because i control when to hear the BOV.....hehe. Thanks in advance!
Old May 17, 2007 | 09:42 AM
Conanski's Avatar
Conanski
A few points here...
8PSI is not low boost in a truck.
Your truck intake won't fit under the hood of a Mountaineer. I think the dealer will notice the hood doesn't close and the engine doesn't look like all the other SUV's on the lot.
You'll have to build custom headers for those GT40P heads or use the stock manifolds from the Mountaineer.
Stock internals are no good for a blown motor, you need low compression forged pistons and high quality fasteners minimum.
IMO, you get more power and better performance in a truck with a hopped up 351 running 9:5-10:1 compression on aluminum heads than with a blown 302.
Old May 17, 2007 | 12:27 PM
95Ford4x4's Avatar
95Ford4x4
your tranny should be an E4od or a 4r70w, no such thing as an e-aod. there is a aod-e, but you shouldn't have that in a 95 model, the mountaineer probably has the car intake for hood clearance. i would go to a junkyard and get the stock parts for the mountaineer, so you can still get the performance stuff for free. but i wouldn't just bolt on the performance and turbo parts onto your motor without a rebuild first. i agree with Conanski that 8psi is more mid level boost. you could go with an adjustable kit where you can go from say 5psi up to 10psi, and figure out where your truck runs best.
Old May 17, 2007 | 11:16 PM
rx7delsol's Avatar
rx7delsol
i agree that 8psi is not that low but why would i need low comp pistons. the comp ratio in the trucks is only 9.0:1 correct that is low enough for 12psi. there are tons of street cars, including my friends honda civic that are running 9.1:1 pistons with 15psi. e4od sorry, so would the tranny be ok? i will rebuild the engine before boost, thats a no brainer. im not worried about the intake just the p heads will be used. sorry for my lack of knowledge, as you see by my name, i drove RX-7s all my life and never owned a piston engine until my f150. i will have a boost controller so thats no prob. so should i just stick to my 302 for this or swap to 351. also i hear that 92-93 mustang roller blocks are a great canidate for a swap because they are already rated at i think 200hp? i hope to god a iron block v8 with low compression can handle 8psi!
Old May 18, 2007 | 12:47 AM
eco's Avatar
eco
You don't NEED to lower the compression of the motor if you are using forced induction as long as you are running the right kind of fuel. Think about it, when the boost kicks in cylinder presure goes up big time. To avoid pre-ignition when boost kicks in on a 9:1 or 10:1 motor (or higher) the proper grade of fuel must be used...I am not sure off hand what that would be but you better not be using cheapo watered down regular!!!
There are many other things to take into consideration when using forced induction such as exhaust, intercooler, bottom end etc etc
Old May 18, 2007 | 07:40 AM
Conanski's Avatar
Conanski
Trucks are 8.5:1 compression ratio, but they weigh twice what a little rice burner weighs so detonation becomes a problem at much lower pressures. It's all about the load on the motor. It can be done, there are a few guys around here with blowers on thier trucks, maybe they will chime in an offer some advice. I know 8psi boost on a stock 5.0HO requires 94 octane the best of times, and when the motor is heat soaked you get into a lot of ignition retard under load. That's only a 3000lb car.
Old May 18, 2007 | 08:57 AM
Blurry94's Avatar
Blurry94
Running the highest octane possible, and a spark plug with a lower heat range than stock, is a must in a boosted application.
I wouldn't consider 8psi a high boost application, however, even a 4-6psi application can destroy a motor if it isn't tuned properly. And if the charge temps are too high, then some type of charge cooling is needed.
Old May 18, 2007 | 10:56 AM
Kemicalburns's Avatar
Kemicalburns
i wouldnt run P heads, do many exhaust limitations there. also they are iron and will be more apt to detonation. if your going with this build properly, locate some AFR heads or trickflow heads
Old May 18, 2007 | 11:39 AM
Blurry94's Avatar
Blurry94
Lower octane fuel, high charge temps and/or poor tuning is the main cause of pre-ignition. I can't tell you how many GEN 1 Lightning owners still run their stock heads (not the P versions though), with boost, and they all run fine when they're dialed in properly.
Trick Flow and AFR heads are excellent options indeed, and will out perform a set of GT-40's.
Old May 18, 2007 | 05:32 PM
rx7delsol's Avatar
rx7delsol
so what about the tranny? I know everything about turboharging, i just need to know now if the tranny will hold up with a valve body kit installed or should i go 5 speed?
Old May 19, 2007 | 07:23 AM
Blurry94's Avatar
Blurry94
A valve body is a good upgrade. A deeper pan and big trans cooler will also help as well.
