Sponsored by: Auxito
using coolant!!
Old Oct 3, 2002 | 07:26 PM
74fencer's Avatar
74fencer
using coolant!!
I have a 98 F-150 with a 6 cylinder in it it seems to be using coolant but there is no visible leaks and it isnt in the oil i do not no where it is going, i usually add about a half gallon every month, any body had the same problem or know where it is going?
Old Oct 4, 2002 | 01:31 PM
rkjerue's Avatar
rkjerue
using coolant!!
[updated:LAST EDITED ON 04-Oct-02 AT 02:35 PM (EST)]Ford puts the water pump inside the engine with the pulley on the outside if the water pump is slowly leaking it will burn off from engine heat before it hits the ground, this happened to a 94 Probe I had, I would check it out.
Old Oct 5, 2002 | 07:07 PM
Racerguy's Avatar
Racerguy
using coolant!!
