Sway bar question
Old May 16, 2007 | 02:58 PM
THE RAT's Avatar
THE RAT
Cool Sway bar question
Can anyone with a 99 SD 4x4 tell me if the raised center section in the front sway bar just about hits on the axel housing were the pinion goes in.
I'm thinking that someone before me put the sway bar on upside down.
Old May 16, 2007 | 03:20 PM
cangim's Avatar
cangim
Mine is flat accross the front. If it looks like it is going to hit, then flip it over, my concern would be when the axle drops, like getting the front airborn, that it would rotate into it. If it is not going to hit then and inch is as good as a mile. Also, mine is a pre 99 so I don't know if the front sway is different between the two, about everything else to do with the axle is.
Old May 16, 2007 | 07:44 PM
zx250's Avatar
zx250
Of the next Riffraff East
Mine is also strait across. You should be able to tell if it has ever hit. If not, don't worry about how close it is. Also, if you have a lift and stock drop arms, that will can your angles and could close the gap.
Old May 16, 2007 | 08:06 PM
Fat Diesel's Avatar
Fat Diesel
My early 99 (10/98 build) has a flat bar as well. It is completely straight between the bushings. It would lie flat on the ground if it was out of the truck.
Old May 16, 2007 | 09:26 PM
THE RAT's Avatar
THE RAT
Thanks for all the input,I took it out and turned it over and now it is also straight across and is no longer near the housing,and every thing looks much better.Also after a test ride the thumping noise under the floor on the left side when going over bumps is also gone!
kawkx500
Apr 4, 2025 04:31 PM
Bronc1
1978 - 1996 Big Bronco
Dec 29, 2013 08:30 PM
pumpdriver20
May 1, 2012 08:29 PM
febigblock
1997 - 2003 F150
Apr 5, 2008 06:15 PM
