waste gate
Old May 16, 2007 | 02:24 PM
dhansen's Avatar
dhansen
waste gate
is it bad to un hook your waste gate rather than getting an aftermarket one?
Old May 16, 2007 | 03:35 PM
ryaneverk2's Avatar
ryaneverk2
Unhooking the red line just takes away PCM control of it. All that'll open it now is if the exhaust gas pressures overcome the weak spring in the actuator, blowing it open. If your stock one is strong, though, no need for an aftermarket. However, one like the BBHA is very strong, and stays shut tight until the PCM tells it to open.
Hope that helps some.
