Truck will not start
Old May 16, 2007 | 12:25 PM
sledge 99's Avatar
sledge 99
I have an 1989 ford F-150 with an inline 6 300 cid. When I turn the key prior to starting, I can hear the fuel pump priming. However, there is lound buzzing sound coming from the pump and pump relay on the inside of the firewall. Truck will turn over but will not start. ( no fire ) Occasionally it will start, but the check engine light is on and truck will run very rough. Sometimes, the check engine light will go off and truck will run good as soon as the light goes off but when it comes back on it will go back to running rough. Does anyone have any suggestions?
Old May 16, 2007 | 01:00 PM
385seriesHemi's Avatar
385seriesHemi
A possible bad relay, could be some bad connections in the pump wiring parts. As for running rough that could be emissions or ignition components.
Old May 16, 2007 | 08:14 PM
elpasoram's Avatar
elpasoram
Have you had your codes retrieved from ECM memory, that could give a good heads up. How's your charging system- good voltage and good grounds?
fivo2fst4u
Nov 8, 2015 06:22 PM
Tyethornton
31
Dec 15, 2014 12:30 PM
clm2012
1983 - 2012 Ranger & B-Series
Jun 8, 2014 07:27 AM
Southern Buckers
21
May 18, 2013 04:22 PM
bigbasshb
May 3, 2010 08:29 AM
