Inline Tranny Filter Housing Stuck
Old May 16, 2007 | 10:24 AM
origcharger's Avatar
origcharger
Angry Inline Tranny Filter Housing Stuck
22 mm 1/2" drive socket and breaker bar not budging it so far. Any tips to employ before I really lean on the bar and break the housing?
Old May 16, 2007 | 10:37 AM
glm racers's Avatar
glm racers
Use an air driven impact wrench set at 50 PSI. Lubricate the o-ring and threads with trans fluid before re-installing it as it will make is easy the next time around.
Old May 16, 2007 | 10:56 AM
blackhat620's Avatar
blackhat620
glm racers,
Yep exactly what "glm racers" said. If you don't have an impact wrench and you have to use a breaker bar make damn sure you have someone or something to support the housing so you don't break any lines or fittings.
I think FMC has a 2000Lb Gorilla they use to put the filter housing on at the factory, they are damn tight the first time you remove them. Lube well or put a little anti seize on the threads before you put it back on.
Old May 16, 2007 | 01:03 PM
LOOnatic's Avatar
LOOnatic
Actually an electric impact is the ticket for this particular job.
The breaker bar can bend the filter bracket and air can be used but do turn it down some like GLM mentioned.
OR, just go by a cheep electric if you have neither.
Old May 16, 2007 | 01:29 PM
origcharger
I have an air impact and so far its not budging at 60 psi.
Thanks everyone, I am about to the point of making sure there is a new one in the area before I go further.
Old May 16, 2007 | 02:34 PM
glm racers's Avatar
glm racers
Secure the clamp that holds the filter housing to reduce the vibrations from the impact wrench. Otherwise the entire assembly will absorbe the impact and not just the cap.
I used long breeze clamps and wrapped them across the frame to secure the housing to the frame.
Just remember that lefty=loosy and righty=tighty when your down there laying on your back looking at the cap. I've made the same mistake while using a long bar to remove the cap and hence why I now use an impact wrench.
Old May 16, 2007 | 02:53 PM
BGMSPD's Avatar
BGMSPD
i spun mine off with an ingersoll rand air impact with it cranked up. don't know exactly how much of the gun i actually used but i just took it easy and it spun right off. breaker bar did nothing for me. it was the first time i changed it at 15,000 miles. didn't torque the bracket at all with the air gun.
Old May 16, 2007 | 05:09 PM
origcharger
Ok, thanks, I kept turning up the air pressure untill I got it off. This was on an E450 van so I was thinking that tranny filter housing was the same composite plastic material that the engine oil filter housing is made of so I maybe was more concerned about breakage than I needed to be.
I did notice that the plate with the spring that goes under the element had numerous cracks in it so wouldn't you know I had to order parts afterall.
Old May 16, 2007 | 11:03 PM
glm racers's Avatar
glm racers
On my F250 both the cap and housing are made of poor quality cast aluminum with pitting and all, but it does meet the minimum design requirements. <O</O
lemasters f100
May 24, 2014 12:08 AM
jredline1984
Jun 19, 2012 11:17 PM
Ratsmoker
13
Jan 7, 2002 09:50 AM
