frame help
Old May 15, 2007 | 09:34 PM
fordage's Avatar
fordage
frame help
on a 1982 regular cab pickup, are the frames the same from a 4wd to a 2wd.
I'm currently restoring a 1982 short box regular cab pickup 2wd with the IFS in front and i thinking of swapping it out with the 4wd IFS. other than the tranny (that i plan on rebuilding anyway)out put shaft, are the frames compatible with the 4wd line components? is it just a bolt up?
Old May 16, 2007 | 10:11 AM
andym's Avatar
andym
Yes, the frames are the same. It's a bolt-in.
