1978 - 1996 Big Bronco
Automatic Hubs(suck)-C-Clips HELP
Old Oct 14, 2000 | 12:13 AM
rebelford's Avatar
rebelford
I am working on changing out my roters and brake pads and installin some new Manual locking hubs. I have the case of the old auto hub off and there is a C-CLIP I need to remove off or something next. What do I do with the c-clip, and how? I have a 95 Bronco. I have the picks and all.
Thanks
Gary
Old Oct 14, 2000 | 11:37 AM
AlM's Avatar
AlM
You'll need a thin flat bladed screwdriver to pop the out snapring just inside the bearing hub right behind the autolocking hub. I also bend a couple of nails to look like an L to reach in the bearing hub to get the bearing nuts and bearing nut lock ring out..is this what you mean?
good luck,
Al
Old Oct 14, 2000 | 03:29 PM
rebelford's Avatar
rebelford
I got it. I ended up using some picks. They were very sharp. Prefect for the job. I am now takin a lunch break and then im gonna see if the new hubs I put on work. Everything was easy to do once I got that dang clip out of there. It took me 4 hours to do the first Rotor and hub. And the second took 30 min. WOW live and learn... Thanks AIM thats what i ended up doin.
Gary
Old Oct 14, 2000 | 08:09 PM
smoothtalkr29483's Avatar
smoothtalkr29483
DoeyDooper
1983 - 2012 Ranger & B-Series
Feb 14, 2017 10:30 PM
Adigo
Jan 3, 2016 10:11 AM
bphirt1
Jun 5, 2015 06:30 AM
thedoctor
Sep 4, 2009 09:36 PM
yosemite
Aug 15, 2002 02:39 PM
