Sponsored by: Auxito
5.4L Coil Pack
Old Jun 1, 2011 | 02:03 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Just to be a pain in the rear.
But the 5.4l never had Coil packs... It had COP (Coil over Plug)...
But.... i see that everyone is still on the same page here. Oh well.
Onward and upward.
Old Jun 2, 2011 | 10:01 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
I worked on an 02 F150 4.6L that had a #5 misfire. The owner put two COPs on it, and several plugs. The problem would be fixed for a couple days then return again everytime. I looked at it and it was missing the hold down bolt for the COP. I found a suitable replacement and fastened it down. When reconnecting I noticed the wire going to the pigtail was rough looking. Turned out it was broken inside, making the miss intermittent. I spliced the wire and it still runs smooth a year later. Probably not your problem, but I figured I'd get it out there to give folks something to look for.
Old Jun 3, 2011 | 08:53 AM
jirwin's Avatar
jirwin
I have an 03 5.4 that has a hard miss. (rpm's drop almost like a stall) it throws the SES light that always comes back as the CPS. Everyone keeps saying I have a bad timing chain. This may be true because you can hear the chain slapping around. I still think it could be COP or wire as well to cause such a miss. Any thoughts? I am torn between paying the 1200.00 for a timing chain or keep saving for a new engine. 140k on engine. Rest of truck in great sape. Sorry for book.
Old Jun 3, 2011 | 08:58 AM
phil6608's Avatar
phil6608
So what are the code numbers and what is CPS?????
Old Jun 3, 2011 | 09:13 AM
jirwin's Avatar
jirwin
Do not remember the number, but dealer and independent shop say it refers to the (cps) Cam position sensor
Old Jul 11, 2011 | 12:36 PM
Steelers&Phillies's Avatar
Steelers&Phillies
Unhappy 97 F150 5.4L Xlt Misfiring/Bucking
I have a 97 F150 5.4L XLT, just replaced all plugs, then my check engine light came on and was bucking alottttt, barely any power goin up hills, had it scanned, it was a misfire on #3, changed the coil pack light went off, 3 days later same thing with bucking and light is back on, again had it scanned misfire on #6, changed coil pack on that, and now again light is on and misfire on #4, is this going to be an on going issue until I switch all the coil packs out or should I just take a match to it ????? Thanks, Pam
FKNVA
Modular V8 (4.6L, 5.4L)
24
May 3, 2021 04:38 AM
meade01
2004 - 2008 F150
Feb 6, 2015 11:56 AM
kunard333
1983 - 2012 Ranger & B-Series
18
Aug 24, 2014 11:17 PM
vanvoorenfamily
25
Nov 13, 2011 11:39 AM
mniewald
Jul 26, 2011 04:46 PM
