2004 Coil Packs
Old Feb 5, 2015 | 12:01 PM
meade01's Avatar
meade01
2004 Coil Packs
My truck has 105,000 miles and I have replaced several coil packs and it is misfiring again. Has anyone else had this much trouble? I have always been a Ford man but damn these cam phaser, coil pack and leaking manifold issues. Thinking about replacing all the coil packs at one time. Any suggestions oem vs aftermarket?
Old Feb 5, 2015 | 04:22 PM
luv2huntnfish's Avatar
luv2huntnfish
coils
I bought aftermarket coils off Amazon & havent had any problems with them.Been running them on my 04 for almost a yr. I believe they came from ARparts and were around $90 for all 8.
Old Feb 6, 2015 | 11:56 AM
cb_13's Avatar
cb_13
Have you replaced the spark plugs? If so did you replace the coil boots when you did? The boots can become formed to the old plug due to heat and then not make a good seal on the new plug. And of course old plugs can cause a misfire themselves or force the coils to work at a higher output causing them to be more likely to fail.
miko6810
May 6, 2014 09:18 PM
njf207
16
Jan 13, 2009 09:25 AM
tofer76
Electrical Systems/Wiring
Oct 16, 2004 11:58 PM
pilot10
Modular V8 (4.6L, 5.4L)
Dec 10, 2003 04:25 PM
