Front Bearings Going How Do I Know?
Old May 15, 2007 | 01:01 AM
Stroked Out!'s Avatar
Stroked Out!
I Have A 03 That I Think That The Front Bearins Are Going Out And Wantted To See If Anyone Could Give Me A Hint Or Two About Some Of The Signs Or Nosies?
Old May 17, 2007 | 10:50 PM
Dieselman929's Avatar
Dieselman929
Besides obvious wobble by grabbing top of tire with both hands and push/pulling it, I've found that the ABS light will come on and not be able to reset due to metal file from bearings collecting on the ABS sensor inside the 2 front hubs.
Old May 18, 2007 | 02:39 PM
BMXdad's Avatar
BMXdad
Here's a couple of things I had. Bearing howl that would increase or decrease with speed, was a bad wheel bearing(non-serviceable). I also had a knuckle seal go out that wiped out the serviceable needle bearing in the hub. When this went it also took out the $200 stub axle. Needle bearing is available from the parts store for about $12.
If you have to change hubs, you'll have to buy 4 new studs and an o-ring from your local Ford dealer for each hub assembly.
