Sponsored by: Auxito
bolt pattern
Old May 14, 2007 | 03:07 PM
bigun72's Avatar
bigun72
Question bolt pattern
will 99 f150 rims fit on a 69 f100 ???
thanks for the help
Old May 14, 2007 | 03:25 PM
KingRanchMan02's Avatar
KingRanchMan02
No, the bolt circle on the `99 is 135mm. IIRC, the bolt pattern back in `69 was a 4.5" circle. I may be wrong on this. So if anyone else knows for sure, please correct me.
Old May 14, 2007 | 03:33 PM
bigun72's Avatar
bigun72
thanks......
Old May 14, 2007 | 05:53 PM
steve(ill)'s Avatar
steve(ill)
prior to 97 the bolt pattern on the F150 size truck was 5.5 inches circle and the Ranger size was 4.5 inches.. back in 1969 i might have been 4.5 i am not sure, but probably 5.5 --- the newer 135mm is close, but will not work, about 1/4 inch off. to hlep out, after 2004 FORD had another good idea and changed the number of bolts ot 6 instead of 5, but still 135 mm circle. What an improvement!!!
Old May 14, 2007 | 06:01 PM
LxMan1's Avatar
LxMan1
Ford trucks have been 5x5.5" since at least 63. in 97, they went to 5 x 135mm
Old May 14, 2007 | 07:58 PM
F-250LD 4x4's Avatar
F-250LD 4x4
I have a 97 250LD thats 7x150mm :-) unique truck
Old May 15, 2007 | 08:54 AM
KingRanchMan02
After I posted the 4.5" circle, I had second thoughts about it being 5.5" instead. Glad you guys corrected me.
