Sponsored by: Auxito
401 Code on a 1998 F150
Old May 14, 2007 | 12:56 PM
gdore28's Avatar
gdore28
Unhappy 401 Code on a 1998 F150
The truck started to run funny with a lack of power with some lurches as you drive. We changed the fuel filter but it still lurches but not all the time. I lloked on the invoice and they say there is an engine light on with a code 401. Could that be causing the lurch? If not, what could it be?
Thanks
Old May 14, 2007 | 01:54 PM
KingRanchMan02's Avatar
KingRanchMan02
Hello gdore and welcome to FTE .
What engine do you have adn how many miles are on the truck? This is a good thread to read on this subject. Good luck!
https://www.ford-trucks.com/forums/2...ighlight=P0401
Old May 14, 2007 | 03:22 PM
gdore28's Avatar
gdore28
It has 187436 miles on it and has a 4.6 L V8 engine.
Thanks
George
Old May 14, 2007 | 03:23 PM
gdore28's Avatar
gdore28
It is also a 1998 F-150. Automatic.
Old May 14, 2007 | 03:30 PM
KingRanchMan02
The 4.6L engine is notorious for the EGR ports clogging up with carbon. This should be mentioned in the thread that I mentioned before. Good luck!
Old May 14, 2007 | 04:14 PM
gdore28's Avatar
gdore28
Thanks for the heads up. It does sound like the problem. I will let you know how it goes.
Thanks Again
George
Old May 16, 2007 | 02:06 PM
God_hammy's Avatar
God_hammy
i would check the dpfe also.. a p0401 code is low egr flow detected. the easiest way to check the egr is to start the truck and apply vacuum to the valve.. if the idle drops and the truck wants to die i would chase after the dpfe
ctfl
Apr 16, 2012 10:54 AM
Warderkous
Jun 4, 2011 09:39 PM
JHUBB58
1997 - 2003 F150
May 17, 2010 10:27 PM
rkjerue
1997 - 2003 F150
Jun 2, 2002 12:11 AM
