squeaky 98
Old May 14, 2007 | 12:08 AM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
Question squeaky 98
my wifes 98 exp squeaks like crazy which is driving her crazy & in turn driving me crazy !
I didn't think it was so bad til I drove it the other nite, man it seems to be coming from every part of the suspension but when I crawl under it can't seem to pinpoint the noise.
I'm going to replace the shocks & go from there.
anyone else with a squeaky suspension and a cure?
the truck has about 140,000m on it and runs great otherwise
Old May 14, 2007 | 08:29 AM
al52269's Avatar
al52269
I also have a 98 Expedition....
I had the same problem. I replace the rear shocks and it stop.
Now its back but I only hear it in the front.
So I'm going to replace the front one's next.
Hope this helps Al
Old May 14, 2007 | 07:21 PM
crew chief's Avatar
crew chief
My 98 sqeaked like crazy untill I sprayed the rear sway bar links, silent as a mouse after that! Might be something to try.
Good Luck
Old May 14, 2007 | 10:56 PM
PaulC's Avatar
PaulC
If the noise is coming from the front, the best suspect is the pitman arm.
Old May 16, 2007 | 03:32 PM
peter57's Avatar
peter57
the ball joints on Expys and F150s are prone to drying out and squeaking. You can check by either driving slowly or compressing the front end at a standstill. It will squeak at small amounts of motion and if it is the ball joints, this should isolate it from other possibilities
Old May 17, 2007 | 11:54 PM
Gevans17's Avatar
Gevans17
Squeaky 98 Expy
My mechanic, who didnt even check the front end, told me it was coming from the lower ball joints......and he was right!!
Old May 18, 2007 | 08:52 AM
peter57's Avatar
peter57
Yeah,they can be pretty annoying, with a constant high pitched squeak. It may be too late but you can replace them with Moog joints that have grease fittings. The stock replacements don't and they eventually do the same thing all over again.
