horn ?
Old May 13, 2007 | 11:29 PM
wizzard351's Avatar
wizzard351
horn ?
anyone have a wiring diagram for the horn on a 71? i took the alt wiring from a 78 to replace the alt section on my 71 awhile back today i realized the horn dont work.the part of the alt wiring i replaced goes from the alt to the plugin on the fender by the solinoid it charges good just no horn
Old May 14, 2007 | 12:13 PM
jdgreen72's Avatar
jdgreen72
it's just a relay. find the wire coming from the column. it hooks to the ground side of the horn relay. there will also be a hot wire, and a wire to the horn.
Old May 15, 2007 | 09:28 AM
Freightrain's Avatar
Freightrain
The horn wire in the column is usually blue with yellow tracer. Like jd mentioned, hook it to relay and you should be back in business.
