1978 - 1996 Big Bronco
A big Clunk!
Old Oct 24, 2000 | 09:50 PM
rick's Avatar
rick
A big Clunk!
Hi All,
A friend has an '82 Bronco w/302. Sometimes at stoplights he will have this loud clunking sound when accelerating as soon he takes off (easy take off) and it feels like the rearend drops about an inch... He has checked for "slop" in all mounting brackets, etc... But, no luck in figuring out the problem... Any suggestions? He also has the NP203 transfer case...
Thanks,
Rick
Old Oct 25, 2000 | 12:44 AM
83bronc's Avatar
83bronc
A big Clunk!
>Hi All,
>an inch... He has
> He also has the
>Thanks,
>Rick
Rick,
Have you checked the drive shaft. Sounds like the u-joint is bad. Try moving the drive shaft side to side to check for movement.
Tim Sponseller
83 Bronco XLT under construction
351W, 6" Superlift suspension, Rancho 9000S shocks, 33x12.5x15 AT's
ntguru@winfire.com
Old Oct 25, 2000 | 06:27 AM
Chuck P.'s Avatar
Chuck P.
A big Clunk!
Check the slip joint in the rear shaft, I recall several others here who had this type of noise when starting out. In some cases it turned out that the splines where dry and would "stick" when first appling power. The bang was when they did start to slide. If you don't have a grease fitting on the shaft at this area, you can take the shaft apart and liberally apply grease to them. Might want to check the archives for some more info.
Old Oct 25, 2000 | 07:45 AM
AlM's Avatar
AlM
A big Clunk!
Rick,
Is the clunk up front?..on driver or passenger side?
If it is, check the ball joints. They tend to clunk upon take-off too.
Old Nov 27, 2000 | 12:44 PM
lowbucksys's Avatar
lowbucksys
A big Clunk!
I own a 96 bronco which developed the same exact problem.
You need to grease the slipyoke on your driveshaft. If it has no grease fitting then you will have to take the rear yoke loose from the differential and remove the rubber boot to grease the slipyoke.Essentially you are taking your driveshaft apart at the slipyoke.
Old Nov 27, 2000 | 04:35 PM
nobody's Avatar
nobody
A big Clunk!
When you re-install the drive shaft, be sure to align the slip joint exactly like it was. They are timed and if your u-joints are not in synch you will most likely have a vibration.
Alan
_____________________________
95 C350-4x4,PSD,4-Door Bronco(Huh?),49K,auto,AIC,switched glow plugs,switched TC lock-up,4.10,Banks PowerPack,straight piped,Mobile-1 gearboxes,Rotella,BFG AT's 295/75/16
Old Nov 27, 2000 | 07:04 PM
hotrodford_88's Avatar
hotrodford_88
A big Clunk!
saturn97sl1
Jan 28, 2014 11:04 PM
mrad
Jun 13, 2013 03:32 PM
Byram
6.7L Power Stroke Diesel
84
Oct 31, 2011 03:25 AM
Oct 13, 2002 12:23 PM
rick adlen
Sep 30, 2002 01:55 PM
