no different than spraying can of xylene, toulene, acetone, ethanol down TB intake while running
if fact safer, all is enclosed
same technique used by auto shops for $150 injector flush
Well used piece of equipment used in many industrial air supply systems, which will protect the fuel system from overpressure damage from any compressor. Good price too!
Only thing to watch out is if the Gumout will attack the polycarbonate feed /drain bowls. Good chance it will be O.K. but with plastics you have to be careful.
