Keep or part out?
Old May 13, 2007 | 12:20 PM
ultimatereality5's Avatar
ultimatereality5
Keep or part out?
I went and bought a 77 F-250 yesterday. Don't know if i want to keep it or part it out though. This is my first real truck (had a 91 2wd ranger at one point) The frame looks good and solid. It has a running 351m in it. And another in the bed. (at least thats what the stickers on the valve covers say)
Good c6. and i don't know much about this but i think it may have the snow fighter package. the front axel looks just like the back one and it has disk brakes. now the bad points. Constant 4x4, will need new tires, rust under door on bottom of body, body is completely rusted out where it mounts to the cab mount (the cab mounts are fine though). and it has a bed off an 88'.
Thats about all i can think of right now.
Do you think i should part it out and use the profits to get something that would be a little bit better of a starter or keep this one to learn on.
Sorry no pics cuz i forgot my camera and the truck is 3 hours away from me.
Old May 13, 2007 | 07:51 PM
fordtruck79's Avatar
fordtruck79
keep it and change cabs if you have to
Old May 13, 2007 | 07:59 PM
ultimatereality5
that would be a bit difficult to find around here (northeast) in the rust belt and very costly. is there any way i can just patch in the body area there. i do plan on making my truck a bit nice, not a restoration to origonal but as nice as i can in my own custom way.
Old May 13, 2007 | 08:16 PM
ag30265's Avatar
ag30265
You can buy replacement sheet metal from www.lmctruck.com If ya have the access to welder's and cutter's you can replace almost all of the sheet metal on the truck............but it'll cost ya.
If the truck is running then I'd have to keep it and repair as funds,time, and parts are available. If ya need as mileage go find a reasonably priced 4 banger, you can drive till ya get the truck finsihed.
Old May 13, 2007 | 08:47 PM
Dustin1690's Avatar
Dustin1690
I agree with ag's idea it is up to you though but yeah rust can be replaced or fixed it is a pain and $$ though
Old May 13, 2007 | 09:13 PM
Thudpucker's Avatar
Thudpucker
Smile
I think any 4X4 is valuable. Especially an automatic.
You can put the locking front hub kits in. That might save you some milage, and it does make it a lot easier to use the truck when not in 4X4.
I've had both.
My current 97 get's only slightly better fuel milage than your 351, but the convenience of 'one lever movment, right in the cab' is very much to my liking.
My wife likes it too.
Those 4X4's are really useful at the boat ramp, and in the winter.
Best consensus? Keep it. it's a great utility vehicle.
Old May 13, 2007 | 09:36 PM
kilog55's Avatar
kilog55
i say keep it but show me pics of the bed wonder how they fabbed up an 88 on it
Old May 14, 2007 | 02:04 PM
ultimatereality5
ok looks like i'm going to keep it then. i'll deffinetly get pics of the bed to show you. thanks everyone for your opinions. i'll be on here for a long time now rebuilding this beast.
Old May 15, 2007 | 06:43 PM
uriah's Avatar
uriah
I've converted a couple full times to part time and it's about not worth doing. I mean MAYBE a little over 1mpg difference if you're lucky. If you just stick locking hubs on it, you won't move when they're unlocked, unless you have the transfer case locked.
If you really want part time, find a NP205 somewhere and bolt it on. I've not been impressed by the parttime kits for the NP203s, plus the 203s make for a really good snow buggy (driving on pavement in bad weather). Again though, the mileage improvement just isn't that great.
I've got a couple of the parttime kits laying around here somewhere... the only real difference I can see, is it'll save some wear and tear on your front diff, but most of these trucks have well over 100K on them anyway, so that's not so much an issue anymore.
Old May 15, 2007 | 09:23 PM
fordtruck79
you can also get replacement panels from jeff's bronco graveyard. they sell quite a bit of them.they have a website just like lmc truck. a good tip would be to use weld through primer to seal any spot you can't paint. works pretty good. also rubberized undercoating is the way to go. use it to cover your floors inside and out, and any place salt might lay. good luck on the build
Old May 16, 2007 | 03:48 PM
samickguy15's Avatar
samickguy15
I say part it and let me buy the axles from you. :-)
If not, fix it and drive it till it dies.
