Sponsored by: Auxito
1999 F150 Question
Old May 13, 2007 | 12:16 PM
TrophyGirl1967's Avatar
TrophyGirl1967
Cool 1999 F150 Question
Please help! I replaced the sensor to the Cool/Hot switch/control which did stop the heat from boiling into the floor, condensor is on the way (which does have a hole) any other troubleshooting to get some AC into this HOT HOT FORD? Also anybody know what the box is with wiring under the oval piece in the passenger dash? I'm a girl so I do have a handicap, Thanks for all the help!
Old May 14, 2007 | 01:20 PM
FTE Trigger's Avatar
FTE Trigger
These guys in the 1997-2003 F150 Forum should be able to help you cool off in your '99 F150...
...And Welcome to Ford-Truck Enthusiasts!
Thread moved..
Old May 14, 2007 | 02:09 PM
KingRanchMan02's Avatar
KingRanchMan02
You may have a cracked **** on your temperature control. Pull the **** off of the temprature control and pull the **** off of the fan switch. Swap the **** positions. If your **** was the problem, you should be able to adjust the temperature now.
