fuel pump problems
Old May 13, 2007 | 10:46 AM
clajoie's Avatar
clajoie
fuel pump problems
i've got another problem with my 99 f-450 thats got me stumped. my fuel pump isn't working. i've checked the fuse with my fluke and it was fine. i unplugged the fuel pump and used a battery charger to jump it and it work just fine. is there some kind of pressure switch somewhere that i should be looking for?
Old May 13, 2007 | 10:59 AM
Uzumati's Avatar
Uzumati
There is an inertia cutoff switch behind the passenger side kick panel.
Old May 13, 2007 | 11:40 AM
clajoie's Avatar
clajoie
if that inetia switch was bad would it cause my problem because the button is pushed in on the switch.
Old May 13, 2007 | 12:23 PM
pentel's Avatar
pentel
Check the pcm power relay in the power distrabution box under the hood, # 30.
Old May 13, 2007 | 12:50 PM
expedition18's Avatar
expedition18
the pcm power relay is working
