Throwing Spark Plugs
Old May 13, 2007 | 09:03 AM
thechief96's Avatar
thechief96
I am still waiting for my 07 SCREW to get here but I have a question on the 5.4 V-8. I have a 99 F-350 with a V-10. It threw a spark plug @ 95,000 miles. I heard that this was more common on the V-8. Has this issue been fixed? I replaced the heads myself and don't want to have to do it again. I must have done it right since I now have over 250,000 on the V-10.
Also how do you get the information under the line describing what you drive?
Thanks
Old May 13, 2007 | 09:14 AM
06Stallion's Avatar
06Stallion
i threw 2 spark plugs when i first got my 06. I had bad fuel injectors from the factory. they changed spark plugs and fuel injectors and no problems since.
Old May 13, 2007 | 09:17 AM
NASSTY's Avatar
NASSTY
I didn't think the 04 + V8s had the plug spitting issue.
Old May 13, 2007 | 10:19 AM
WhëëlMå1's Avatar
WhëëlMå1
They dont.
Old May 13, 2007 | 02:01 PM
thechief96's Avatar
thechief96
Thanks for the info.
Old May 13, 2007 | 04:33 PM
Firemut30's Avatar
Firemut30
Go to the user CP,there you can modify all you personal settings.
Old May 18, 2007 | 09:07 AM
tonygauvin's Avatar
tonygauvin
Thanks
I had the same problem with my 1999 F-350 V-10 @ 38,000 (just past warranty!). I replaced the heads with no further issues. I have heard hat the newer tritons V-8's have the the opposite problem; you can't get the plugs out of the head without breaking them, There is a TSB out on the issue and ford has a specialty tools to remove broken plugs. I will be changing the plugs on my 2006 F150 Larait @ the 10K service interval just for safe measure, the truck has 5K on it now.
Old May 18, 2007 | 01:06 PM
96f150's Avatar
96f150
Not sure when Ford starting using the 3V 5.4 in the Superduty, but in 04 when they cam out with the new body style F150, this was the first year for the F150. The older 5.4 2v along with the 6.8, were the ones spitting plugs out. The new 5.4 3V, you Can't get them out without them breaking off usually. A lot of guys have had very good success with changing them around 30k. I would not wait until the 100k mark.
Rich
Old May 18, 2007 | 01:11 PM
WhëëlMå1's Avatar
WhëëlMå1
I believe the 2004 trucks had the 2V (even though the half tons had the 3V), but the 2005 Super Dutys got the extra valves.
Old May 18, 2007 | 02:24 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
why. not to step on toes, but why risk breaking your plugs when they clearly don't need to be done. I'd say 50,000 miles at the earliest unless you start to exhibit a rough idle and decreased MPG due to bad plugs
but yeah, the 5.4 2v and the 4.6 2v had issues with insufficient threads on the spark plugs. this could lead to the plug threads stripping and the spark plug "ejecting" from the cylinder.
Old May 18, 2007 | 02:57 PM
tonygauvin's Avatar
tonygauvin
I have several reasons. The first is that when the spark plug problem happened on 1999 V10 it was 5K out of warranty and cost me $1500 to repair (new heads). This time I will have the ford service tech work on my removing plugs IAW TSB # 06512 which tells them to put anti-seize on the new plugs threads. Funny thing about Ford is even when they know they created the problem they will only take care of it if it is under warranty. I figure I'll send $100 now instead of $1500 later. Besides there are better plugs than the factory autolites so I was as well put in some better plugs now. Changing plugs @ 50K means it is out of warranty, I have a 2006. (see below for both trucks)
Old May 18, 2007 | 03:11 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I don't know if they told you, but if the plugs break
YOU HAVE TO PAY FOR THE EXTRACTION
If you're lucky, that special tool will work, but most likely the head will have to be pulled. I'd make very sure of all the costs, and potential costs before touching those plugs. I'm worried about the breakage also, but I'll be doing it at the 50k mark myself. I'm not in the mood to pay thousands for a repair that isn't needed just yet to prevent a plug from maybe getting stuck. just my opinion though
Old May 18, 2007 | 03:32 PM
KevinM's Avatar
KevinM
The 2004 1/2 ton new body style was the first for the 5.4 3V. Do not have plug launcing issues.
Old May 19, 2007 | 08:24 AM
tonygauvin's Avatar
tonygauvin
Not according the Maine *where I live* state consumer law. I have already have this covered with the dealer.
Old May 19, 2007 | 10:31 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
then your in the clear...some people have already tried this and had to pay for the extraction...good luck on them not breaking anyways
GoodandPLENTY
May 27, 2016 12:17 AM
WorldCommander
Jan 13, 2016 01:51 PM
f250mtnbikr
Modular V10 (6.8l)
Mar 13, 2015 06:38 AM
guruatbol
Jun 11, 2005 03:10 AM
